Prime wrote:
Oh and Mike, thanks for the water issue suggestions. Your explanation would cover the symptoms we are seeing, I hadn't thought of that. We will check it out. I do believe we replaced the tubing at that annual. Are you suggesting that the old tubing may have leaked just enough to trap the water, where previously it would have drained? What would be different with new scat tubing? As Jim said, the opposite is likely true. The old tubing was probably beat up and perforated in several spots, thus letting the water OUT that was leaking in from the airbox. If you remove the nose cowling, I can almost guaranty some cracks in the airbox. Hold the cowling upright in its normal position, spray water at the front from a high up angle (mimicking rain), and look to see where it runs. I'll bet it goes into cracks and out the round tube that connects to the scat tube. All it takes is an ounce or two. As I said, I had the exact same problem after replacing my main induction scat tube. A little hole punched in the bottom cured it. Until then, start it up with the carb heat valve opened half-way to prevent the water from being sucked in on startup. Good Luck, Mike |
FS: PA28-140 | Steve Foley | Aviation Marketplace | 0 | November 27th 06 01:06 PM |
FS: 1966 PA28-140 | Steve Foley | Aviation Marketplace | 0 | July 3rd 06 12:36 PM |
FS: 1966 PA28-140 | Steve Foley | Aviation Marketplace | 0 | February 4th 06 11:48 PM |
Price for PA28-180 | Billy | Owning | 12 | November 5th 04 04:37 PM |
PA28 gas cap | Frank Van Haste | Owning | 19 | July 24th 03 07:17 PM |
