Prime wrote:
Mike, thanks for the feedback. One comment, at previous times the boost pump clicking would usually stop once pressure was built up in the lines. When this problem occurs the clicking never stops. I don't think that's normal, since it doesn't occur when we get a "normal start"? Although I believe this is unrelated to your problem, it does not sound normal in the opposite way you are describing. I believe they should never stop running. It has been many years since I dismantled an electric fuel pump, but I believe these pumps have a spring loaded internal bypass valve that maintains pressure. They are made to run constantly. If they stop, that indicates a problem. Wrenches? Good luck, Mike |
Mike Spera wrote:
Prime wrote: Mike, thanks for the feedback. One comment, at previous times the boost pump clicking would usually stop once pressure was built up in the lines. When this problem occurs the clicking never stops. I don't think that's normal, since it doesn't occur when we get a "normal start"? Although I believe this is unrelated to your problem, it does not sound normal in the opposite way you are describing. I believe they should never stop running. It has been many years since I dismantled an electric fuel pump, but I believe these pumps have a spring loaded internal bypass valve that maintains pressure. They are made to run constantly. If they stop, that indicates a problem. Wrenches? Good luck, Mike On mine, it continues to run but it gets a lot quieter once the fuel pressure builds up. Does your pressure build to the normal level when this happens? Could be that the fuel pump needs new seals. |
FS: PA28-140 | Steve Foley | Aviation Marketplace | 0 | November 27th 06 01:06 PM |
FS: 1966 PA28-140 | Steve Foley | Aviation Marketplace | 0 | July 3rd 06 12:36 PM |
FS: 1966 PA28-140 | Steve Foley | Aviation Marketplace | 0 | February 4th 06 11:48 PM |
Price for PA28-180 | Billy | Owning | 12 | November 5th 04 04:37 PM |
PA28 gas cap | Frank Van Haste | Owning | 19 | July 24th 03 07:17 PM |
