Need help with a problem in our PA28-140
Old February 16th 07, 02:02 AM posted to rec.aviation.owning
Ray Andraka
Default Need help with a problem in our PA28-140
Mike Spera wrote:
Prime wrote:
Mike, thanks for the feedback. One comment, at previous times the
boost pump clicking would usually stop once pressure was built up in
the lines. When this problem occurs the clicking never stops. I don't
think that's normal, since it doesn't occur when we get a "normal start"?
Although I believe this is unrelated to your problem, it does not sound
normal in the opposite way you are describing. I believe they should
never stop running.
It has been many years since I dismantled an electric fuel pump, but I
believe these pumps have a spring loaded internal bypass valve that
maintains pressure. They are made to run constantly. If they stop, that
indicates a problem.
Wrenches?
Good luck,
Mike
On mine, it continues to run but it gets a lot quieter once the fuel
pressure builds up.
Does your pressure build to the normal level when this happens? Could
be that the fuel pump needs new seals.
FS: PA28-140 Steve Foley Aviation Marketplace 0 November 27th 06 01:06 PM
FS: 1966 PA28-140 Steve Foley Aviation Marketplace 0 July 3rd 06 12:36 PM
FS: 1966 PA28-140 Steve Foley Aviation Marketplace 0 February 4th 06 11:48 PM
Price for PA28-180 Billy Owning 12 November 5th 04 04:37 PM
PA28 gas cap Frank Van Haste Owning 19 July 24th 03 07:17 PM
