gear up landing of a Piper Arrow
Old February 16th 07, 05:25 PM posted to rec.aviation.piloting
Al G[_1_]
Default gear up landing of a Piper Arrow
"Jim Macklin" wrote in message
"other three?" Who knew the Arrow had 4 ?
And isn't "three gear get stuck in the down position." what you want?
Al G
"buttman" wrote in message
| http://abclocal.go.com/kfsn/
| click on "emergency response to troubled plane"
| An arrow tried to bounce the plane on the runway to get
the stuck
| landing gear to come down, but all it did was make the
other three
Old February 16th 07, 07:35 PM posted to rec.aviation.piloting
Jim Macklin
Not on take-off.
Wheels down is only really important for the next take-off.
"Al G" wrote in message
| "Jim Macklin" wrote
in message
what you want?
| Al G
get
| the stuck
| other three
Old February 16th 07, 09:28 PM posted to rec.aviation.piloting
buttman
Al G
roups.com...
the stuck
other three
gah. I meant to say the Arrow has 1 gear that was stuck up, and the
other two were down. After the bouceing (which I have never heard of
anyone doing), the two that he was able to get down, were then stuck
in the down position. I was always under the impression that it's
better to land on the plan's belly (with no gear down) than it is to
land with only 2 of the 3 gear down.
Old February 16th 07, 11:42 PM posted to rec.aviation.piloting
Jose
Well, if the gear can keep the prop from striking, that's a good thing.
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
Old February 17th 07, 05:09 AM posted to rec.aviation.piloting
Jim Macklin
Let the prop strike at full power, you want a new firewall
forward. With a two blade prop, land on the mains, hold the
nose off and shut the engine down, it might even stop with
the blades horizontal.
But if you can get the mains down, you'll have a normal
landing, brakes and steering control. Very little damage to
the structure and probably zero injuries.
"Jose" wrote in message
. net...
than it is to
a good thing.
| Jose
deep need to
Whosoever fully
Old February 17th 07, 02:35 AM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Having done it, I speak from experience: yes, it's better simply because you
have less chance to damage something. The only real difference is that when you
run out of rudder authority, you're going to turn no matter what you do. If I
had it to do over again, I'd line up on the opposite side of the runway so I'd
have more room to swing. Whichever gear doesn't come down... that's the way
you're going to turn.
All in all, it's pretty much a non-event. The media makes it out to be an
emergency but I'd call it a nuisance at most. You're not going to fly it again
for a while but nobody is likely to get hurt.
mschnerdatcarolina.rr.com
Old February 17th 07, 02:47 AM posted to rec.aviation.piloting
Travis Marlatte
Al G
roups.com...
the stuck
other three
Probably but I would have tried bouncing too. I doubt that it was the
bouncing that caused the two to get stuck down.
Travis
Lake N3094P
PWK
Old February 17th 07, 05:06 AM posted to rec.aviation.piloting
Jim Macklin
Always better to land with the mains down or with them up if
wing and nose. But A proper pre-flight and maintenance
reduces the issue to a rare case. But then lots of people
don't do the maintenance they should do.
| "Jim Macklin"
| Al G
roups.com...
get
| the stuck
| other three
up, and the
never heard of
then stuck
that it's
than it is to
Old February 18th 07, 04:34 AM posted to rec.aviation.piloting
Robert M. Gary
On Feb 16, 9:06 pm, "Jim Macklin"
Its amazing how often such a stuck gear situation follows immediately
after maintenance or after a really hard landing.
-Robert
Old February 18th 07, 09:58 AM posted to rec.aviation.piloting
Jim Macklin
Recap tires, tires over inflated, low strut or over inflated
strut, tow bar still attached to nose wheel.
I actually had some first hand knowledge of that incident.
Pilot flew in late in the evening, line person had to get
special tow bar for the aircraft. Line boy left it on the
aircraft, to speed up the departure the next morning.
Pilot comes out at dawn, does a "thorough pre-flight" and
takes-off with the tow bar adapter still on the nose wheel
[Piper Arrow]. Aircraft was high time.
Nose wheel stuck 1/2 way up, Pilot flew around for a while
and then landed. Airframe damage was limited to nose and
firewall. In my mind the pilot was solely responsible since
that big chunk of red painted iron was visible.
But the FBO bought the pilot a new engine, prop, and all
other parts and installed them at no charge. I guess they
thought that a jury might not understand the phrase "pilot
in command."
ps.com...
up if
people
immediately
| -Robert
Cessna Cardinal 177 RG II v. Piper Arrow III (70s) v. Piper Arrow III (brand new) [email protected] Piloting 90 September 23rd 06 12:48 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
Piper Arrow Add-on for FS2004? [email protected] Simulators 1 June 30th 05 01:27 AM
Piper Arrow vs Cessna 182 [email protected] Owning 28 June 27th 05 03:26 PM
Arrow auto gear extension oddness Roy Smith Owning 10 March 8th 04 02:27 AM
