In rec.aviation.owning DL wrote:
Very long shot, I know, but - does anyone have any schematic or any documentation whatsoever on a pilot controller runway light controller, Model BX-2, made by Subil Enterprises, Inc., Des Moine, IA 50317? Does it have its own receiver or does it plug into the audio output of another receiver? Problem is very low sensitivity. How's the antenna, coax to the antenna, and any other connecting cables? These crap out with surprising regularity. (This applies even if the light controller is plugged into another radio.) If the antenna is also used for transmitting, and you can get an SWR meter, you might check the SWR to see if it's way high. If the controller plugs into the output of another receiver, have you tried the controller with a different receiver? Inside the box, even without a schematic, you can check a few things. Some you can do with a multimeter and some need an oscilloscope. Power supply up to snuff - steady, ripple-free voltages? Depending on the voltages, you might be able to temporarily substitute a battery, which is almost guaranteed to give you "clean" power. In something of that age, the filter capacitors on the power supply are likely suspects. Get a strong light and a magnifying glass and check all the solder joints, especially ones to massive components and off-board wires. Especially check the input jack (antenna or audio) - these are often subject to mechanical damage from the cables that are plugged into them. Check the first few components immediately after the input jack (antenna or audio). These bear the electrical brunt of goofy signals coming in the input. See if resistors and capacitors are open, shorted, or have changed value dramatically. See if inductors are open. You might have to unsolder one end of the component involved for a good test. If it has its own receiver, and is crystal-controlled (you can't program in the frequency), check the crystal for oscillation at the proper frequency and/or swap in another crystal. This may cost you a few bucks and some time for the new crystal, so it's not first on the list. Resist the temptation to adjust any internal trimpots or coils at first. If you can't resist, mark them well so you can put them back where they were when the adjustment doesn't help. "I will remember where it was" is not a mark. Google says this guy http://fmi.typepad.com/lwyp/2006/10/..._lighting.html was looking for information on a similar unit; you might contact him and see if he found anything. Disclaimer: This is based on experience with electronic equipment in non-aviation applications. I am not an avionics technician. I don't have an A&P; I don't even have a TG&Y. Your mileage may vary. Matt Roberds |
Thank you very much for your detailed response. Answers to your
questions/comments, below: wrote in message ... In rec.aviation.owning DL wrote: Very long shot, I know, but - does anyone have any schematic or any documentation whatsoever on a pilot controller runway light controller, Model BX-2, made by Subil Enterprises, Inc., Des Moine, IA 50317? Does it have its own receiver or does it plug into the audio output of another receiver? It has its own receiver, power supply, logic to respond to unicom clicks to turn lights on and off and power relay for runway lights. Problem is very low sensitivity. How's the antenna, coax to the antenna, and any other connecting cables? These crap out with surprising regularity. (This applies even if the light controller is plugged into another radio.) If the antenna is also used for transmitting, and you can get an SWR meter, you might check the SWR to see if it's way high. Have checked antenna coax and connections and found no problems, including continuity/shorts check of antenna (very short cable). If the controller plugs into the output of another receiver, have you tried the controller with a different receiver? Inside the box, even without a schematic, you can check a few things. Some you can do with a multimeter and some need an oscilloscope. Power supply up to snuff - steady, ripple-free voltages? Depending on the voltages, you might be able to temporarily substitute a battery, which is almost guaranteed to give you "clean" power. In something of that age, the filter capacitors on the power supply are likely suspects. Power supply checked with voltmeter and scope; seems clean, may try with battery or alternate power supply. Get a strong light and a magnifying glass and check all the solder joints, especially ones to massive components and off-board wires. Especially check the input jack (antenna or audio) - these are often subject to mechanical damage from the cables that are plugged into them. Check the first few components immediately after the input jack (antenna or audio). These bear the electrical brunt of goofy signals coming in the input. See if resistors and capacitors are open, shorted, or have changed value dramatically. See if inductors are open. You might have to unsolder one end of the component involved for a good test. Will do. First section is FET RF amp. Will look closely in that section If it has its own receiver, and is crystal-controlled (you can't program in the frequency), check the crystal for oscillation at the proper frequency and/or swap in another crystal. This may cost you a few bucks and some time for the new crystal, so it's not first on the list. Is crystal controlled. Have tried frequencies above and below the 122.9 spec. to see if I could detect a higher sensitivity off frequency. So far, no definitive results. It works, but handheld needs to be close to the antenna. Resist the temptation to adjust any internal trimpots or coils at first. If you can't resist, mark them well so you can put them back where they were when the adjustment doesn't help. "I will remember where it was" is not a mark. Have successfully resisted that temptation thus far. Good advice. Google says this guy http://fmi.typepad.com/lwyp/2006/10/..._lighting.html was looking for information on a similar unit; you might contact him and see if he found anything. Had seen that too. Good advice to try to contact him. Is a different unit. Hamtronics sells a solution. Much more capable board, $229, plus wall wart PS, plus solid state power relay. Such a full solution (with my packaging) could be had for under $300 - not enormous when absorbed by a number of folks. But I am stubborn and would like to find the culprit in this box, as the fix, if found will be less than $5 including shipping and sales tax, from Mouser. And I'll chalk my time off to a "learning experience" . . . . up to a point, at least! Disclaimer: This is based on experience with electronic equipment in non-aviation applications. I am not an avionics technician. I don't have an A&P; I don't even have a TG&Y. Your mileage may vary. Matt Roberds Thank you again. Obviously you've had some real experience with troubleshooting. The beauty of this situation is that you don't have to be an A&P, IA, FCC, anything that I know of. It's at a private field. No one is guaranteed that it works every night. But it has for years, until now. DL |
Thank you very much for your detailed response. You're welcome. It sounds like you're ahead of me anyway. ![]() Usenet, "I need a schematic" requests tend to fall into two categories: either "I don't know which end of a soldering iron to hold but I think a schematic will tell me everything" and "I already checked all the easy stuff with no luck and need a schematic to go further". I ass-u-med that your query was in the former category but it was actually in the latter. First section is FET RF amp. Will look closely in that section I know there will probably be some protection, tuning/filter, and impedance matching components between the antenna input and the FET, but to me FET usually means "easy to zap with static/overvoltage". This is probably more true on equipment of that vintage. Matt Roberds (Note: This post may appear twice. Since Cox outsourced their news servers to Highwinds Media, news doesn't work worth a damn here.) |
Limiting use of Pilot Controlled Lighting | [email protected] | Instrument Flight Rules | 9 | June 19th 06 10:33 PM |
Lighting Controller Updated | [email protected] | Home Built | 0 | January 11th 05 05:34 PM |
Lighting Controller Updated | [email protected] | Aviation Marketplace | 0 | January 11th 05 05:30 PM |
Cockpit Lighting Controller | Richard | Owning | 1 | May 4th 04 07:25 PM |
Cockpit Lighting Controller | Richard | Home Built | 0 | April 8th 04 07:12 AM |
