If user fees go into effect I'm done
Old February 17th 07, 01:13 PM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
mike regish
Default If user fees go into effect I'm done
Except that there are no present conversions that deal with ethanol.
mike
"scott moore" wrote in message
Most likely we'll be lining up for autogas conversions.
Which will increase the pressure for user fees.
And on and on and on.
Scott
  #172
Old February 17th 07, 01:32 PM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Steven P. McNicoll
"Sam Spade" wrote in message
You're right as to the timing. But, the 707 was a direct direvative of
the 135 development program. And, as I recall, the development program
was for the C-135. The tanker came later.
The KC-135A preceded the C-135A by four years.
  #173
Old February 18th 07, 01:43 AM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Judah
Mxsmanic wrote in
I strongly suspect that GA is more of a burden than an asset for the
population and society at large. Commercial air travel is a necessity;
general aviation is not.
Your statement is equivalent to saying that commercial land vehicles (cars
& trucks) are a necessity, but private ones are not. The only difference is
that fewer pilots fly privately than drivers who drive privately.
But what you don't recognize is that GA is necessary to maintain the
infastructure of the commercial airlines. For example, FBOs in many small
airports would not be able to support themselves or their employees without
the income produced from servicing and storing these private aircraft. At
my airport, the GA ramp has hundreds of planes each paying several hundred
dollars a month just for a tie down. They also provide fuel for these
aircraft, and have a crew that lays out the
They also handle service for a small number of GA fractional jet share
clients, and do overnight service and storing of a small number of Airline
jets. However, I doubt they could support their current structure just on
the fees associated with fueling up some NetJets and towing Dash-8's for
United to a hangar.
More importantly, though, without the GA system, there would be limited
opportunities for people to build the required experience to become a safe
commercial aviator. There would probably also be a reduced lack of
interest.
So perhaps you have not observed the full extent of the picture, and have
made a judgement based on incomplete or innacurate theories...
  #174
Old February 18th 07, 03:01 AM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Mxsmanic
Judah writes:
No, it's not even remotely close to that.
The only difference is that fewer pilots fly privately than drivers
That difference is huge: there are about 400 licensed drivers for every
licensed pilot, and while licensed drivers tend to drive fairly regularly,
licensed pilots do not (it's just too expensive, usually). In fact, private
pilots spend more time in a car driving to and from the airfield than they
spend in the air, in many cases.
Many people drive cars because they have to. They can't hold a job without a
car. It's hard to find any situations in which this is true for general
aviation and private pilots.
United to a hangar.
A lot of airports would simply disappear without GA, as they would no longer
serve any purpose. The airlines don't need them.
interest.
Commercial aviators can be trained from scratch in simulators; small aircraft
are only used because current regulations require it, but regulations can be
changed.
No, I've seen the picture objectively, and not through the rose-colored
goggles worn by many pilots. The fact is, general aviation by private pilots
could disappear in a puff of smoke tomorrow, and it would have no effect at
all on society at large.
It's important to keep this in mind when trying to influence or shape public
policy with respect to GA. The vast majority of the population cares nothing
about your flying, and would not miss it if it were gone; so if you want to
persuade that population, you need a method that doesn't depend on the
subjective appeal of flying an aircraft (which doesn't exist for most people).
Indeed, if you concentrate too much on this aspect, you may alienate the
majority, and you definitely don't want to do that.
  #175
Old February 18th 07, 06:50 AM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Judah
Mxsmanic wrote in
Judah writes:
(cars & trucks) are a necessity, but private ones are not.
I think it is exactly the same, except replace the word "land" with "air".
longer serve any purpose. The airlines don't need them.
Your definition of GA is inconsistent. Here you say GA is anything but
airlines. Before you said GA is anything that is not commercial.
aircraft are only used because current regulations require it, but
regulations can be changed.
I don't think that is practical. How many hours of training are required to
learn to fly safely in a simulator? The pilot wouldn't even understand the
behavior or proper use of Trim without any actual flight time. This is
safe?
pilots could disappear in a puff of smoke tomorrow, and it would have no
effect at all on society at large.
Your goggles are equally as colored as mine, if not moreso.
public policy with respect to GA. The vast majority of the population
cares nothing about your flying, and would not miss it if it were gone;
so if you want to persuade that population, you need a method that
doesn't depend on the subjective appeal of flying an aircraft (which
doesn't exist for most people). Indeed, if you concentrate too much on
this aspect, you may alienate the majority, and you definitely don't
want to do that.
I'm not shaping public policy.
  #176
Old February 18th 07, 07:39 AM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Mxsmanic
Judah writes:
Call it commercial and non-commercial, then.
Fewer than the number required in a real aircraft, mainly because a simulator
can simulate all sorts of things that are impractical, expensive, or truly
dangerous in a real aircraft.
The pilot wouldn't even understand the behavior or proper use of Trim
Sure he would. The simulator works just like the real aircraft.
This is safe?
Absolutely. And much cheaper than using real aircraft. That's why it is so
attractive for training. Only regulatory barriers prevent it from being done
in the U.S.
  #177
Old February 18th 07, 10:13 AM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Chris
"Newps" wrote in message
The last time we had this fight was 10 years ago, the current system has
to be decided no later than Sept 30 because there is a sunset provision in
what we are doing now. They will, in the end, reauthorize the current
system pretty much as is. Taxes on airline tickets and per passenger fees
may get adjusted slightly.
The best way to tax is per ticket or passenger not on the value of the
ticket. That way the tax is not revenue dependent but movement dependent.
The Low costs airlines put less into the taxes whilst having more activity
which does not make sense.
  #178
Old February 18th 07, 04:13 PM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Judah
Mxsmanic wrote in
You yourself expressed a lack of understanding of trim.
Simulator time alone is not sufficient for safe flight.
  #179
Old February 18th 07, 05:09 PM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Mxsmanic
Judah writes:
What did I misunderstand about trim?
Actually it is. And in the future you will see airline pilots even in the
U.S. who have trained exclusively on simulators prior to their first revenue
flight with passengers. As technology evolves, training in a tin can for
flying an airliner is becoming as irrelevant as training in a rowboat for
piloting a supertanker.
  #180
Old February 18th 07, 06:07 PM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
Alan Gerber
Or maybe per passenger-mile?
.... Alan
Alan Gerber
PP-ASEL
gerber AT panix DOT com
If user fees go into effect I'm done [email protected] Piloting 286 February 20th 07 02:02 AM
Trouble ahead over small plane fees AJ Piloting 90 April 15th 06 01:19 PM
What will user fees do to small towered airports Steve Foley Piloting 10 March 8th 06 03:13 PM
GA User fees Jose Piloting 48 December 24th 05 02:12 AM
The Irony of Boeing/Jeppesen Being Charged User Fees! Larry Dighera Piloting 9 January 23rd 04 12:23 PM
