On Feb 19, 6:00 am, Thomas Borchert
wrote: One thing I haven't figured out yet is where to put the handheld backup GPS (we have a Garmin 430 in the plane). I would NEVER fly without at least a handheld GPS in IMC (if there is none in the panel - if there is, I still like the backup). The cost of that safety device has become trivial, with the Lowrance Airmap 500 or 600c. One can put it on the yoke, and I would if it were my primary GPS, to have it in the scan. But in my set-up, it then gets obscured by anything on the yoke clip. I have a Geko 201 I toss up on the glareshield. I used to use it simply to record tracks, but now for IMC trips I will set it to "navigate-to" my destination airport. No map; only track, desired track, distance, and altitude. But I do train with it, so it would be sufficient in the event of complete electrical failure.... Cheers, John Clonts Temple, Texas N7NZ |
Lots of good advice.
For timers, I use: http://www.lcflight.com/timers.html "4 Channel Alarm /Clock Timer" #1 is the 'active' timer (expected times, times approaches, etc.), #3 and #4 are fuel tanks. #2 is the countdown for beverage and meal service, ie I dont' use it. ;-) My CFII said it was too complicated but I had used it when I worked in a laboratory and it is very simple to use. A few weeks later after he told me this, I saw a picture of the cockpit of SpaceShipOne and it had one mounted in it. ![]() Gerald |
I skip all the fancy stuff. Lots of pens (so if I drop I have
another), the writing pad (I use the 4x6 ones), enroute chart and terminal charts (bound govt--much sturdier), two pairs of reading glasses. All I need. There is a flashlight or two, but I don't fly in IMC at night. Put the heading into the heading bug, the altitude into the altimeter bug and the freq into the radio. I find that to be a godsend over trying to write everything down. I do write down initial clearances, because they are usually long. I just file everywhere direct (I have IFR GPS), and take what I get, unless I know how to get something special out of ATC (then I file that). I don't need a timer, but if I did, I'd just use my wris****ch. I store my pencil in my shirt pocket. Nothing fancy. If you do buy a bunch of fancy stuff, buy the cheap stuff. That way when you throw it out, it won't hurt as much. On Feb 18, 7:33 pm, wrote: What methods do you deploy? How many folks use a kneeboard? What kind of timer (analog or digital stopwatch) do you use, and where do you put it? Where do you keep the charts, approach plates, and scratch paper? How many people write down every clearance, heading, altitude and frequency change? How do you keep from dropping your pen (or pencil)? Is it on a string? Where do you put in when not in use? Velcro? Your pocket? I've read the books, but I just wonder how people cope in real life. Rod Machado talks about using a clipboard (with extra clips on the 3 other sides) in his excellent training manual. This seems like a good idea to me. Steve PP ASEL Instrument student |
Doug wrote:
snip If you do buy a bunch of fancy stuff, buy the cheap stuff. That way when you throw it out, it won't hurt as much. On Feb 18, 7:33 pm, wrote: What methods do you deploy? How many folks use a kneeboard? What kind of timer (analog or digital stopwatch) do you use, and where do you put it? Where do you keep the charts, approach plates, and scratch paper? How many people write down every clearance, heading, altitude and frequency change? How do you keep from dropping your pen (or pencil)? Is it on a string? Where do you put in when not in use? Velcro? Your pocket? I've read the books, but I just wonder how people cope in real life. Rod Machado talks about using a clipboard (with extra clips on the 3 other sides) in his excellent training manual. This seems like a good idea to me. Steve PP ASEL Instrument student Nobody had mentioned this. I do use a clipboard and put velcro around the pen. I have the mating velcro on the edge of the clipboard. It is always where I need it. I haven't dropped it yet, but I keep a back up in the shirt pocket. -- Regards, Ross C-172F 180HP KSWI |
I'd like to to consider another organizational skill for flying in
IMC, this is related to approaches etc. Always -- make that ALWAYS -- brief yourself on the approach, but with this important difference. You may have said to yourself "OK, final approach fix at 3500, fly 210 degrees, descend to 2150, fly for 2 minutes 30 seconds, land. Don't do that! Always self brief the miss. "Fly for 2 minutes 30 seconds, look for the airport, full throttle, gear up, establish positive climb rate, report the miss to approach, maintain 210 degrees, climb to 4000, left turn," Always treat seeing the airport as a happy accident -- you know how to land, don't sweat that. In real life, especially if you're flying into uncontrolled airports, you may be flying missed approaches one time in 20 or 1 time in a hundred, and I want you to be ready for that exceptional time. It'll be handy on your check ride, too, because you just know the examiner is going to tell you to fly the miss at a time when you're focusing on landing. Treat this advice like the others you have gotten -- if it makes sense to you, make it your own. But trust me on this. This mind set, that seeing the runway at MDA is a happy accident, and you've already planned to fly the miss, will save you a lot of workload at a critical time. I can't imagine a downside, although some readers may find one. On Feb 18, 9:33 pm, wrote: What methods do you deploy? How many folks use a kneeboard? What kind of timer (analog or digital stopwatch) do you use, and where do you put it? Where do you keep the charts, approach plates, and scratch paper? How many people write down every clearance, heading, altitude and frequency change? How do you keep from dropping your pen (or pencil)? Is it on a string? Where do you put in when not in use? Velcro? Your pocket? I've read the books, but I just wonder how people cope in real life. Rod Machado talks about using a clipboard (with extra clips on the 3 other sides) in his excellent training manual. This seems like a good idea to me. Steve PP ASEL Instrument student |
the airport, full throttle, gear up, establish positive climb rate, report the miss to approach, maintain 210 degrees, climb to 4000, left turn," Good advice to brief and be ready for the missed approach. However, for the actual mechanics of the missed, I'd add as the first step "pitch up to climb attitude" (generally about 10 degrees, or 2-3 bar widths). Many times on an instrument proficiency check I've seen the pilot add full power without a definite pitch up, and spend a lot longer than he should down near 200 feet. Absolute priority on the missed is to get the climb established, and you do this with both pitch and power. Barry |
On Feb 19, 6:10 pm, "Tony" wrote:
I'd like to to consider another organizational skill for flying in IMC, this is related to approaches etc. Always -- make that ALWAYS -- brief yourself on the approach, but with this important difference. You may have said to yourself "OK, final approach fix at 3500, fly 210 degrees, descend to 2150, fly for 2 minutes 30 seconds, land. Don't do that! Always self brief the miss. "Fly for 2 minutes 30 seconds, look for the airport, full throttle, gear up, establish positive climb rate, report the miss to approach, maintain 210 degrees, climb to 4000, left turn," Always treat seeing the airport as a happy accident -- you know how to land, don't sweat that. In real life, especially if you're flying into uncontrolled airports, you may be flying missed approaches one time in 20 or 1 time in a hundred, and I want you to be ready for that exceptional time. It'll be handy on your check ride, too, because you just know the examiner is going to tell you to fly the miss at a time when you're focusing on landing. Treat this advice like the others you have gotten -- if it makes sense to you, make it your own. But trust me on this. This mind set, that seeing the runway at MDA is a happy accident, and you've already planned to fly the miss, will save you a lot of workload at a critical time. I can't imagine a downside, although some readers may find one. On Feb 18, 9:33 pm, wrote: What methods do you deploy? How many folks use a kneeboard? What kind of timer (analog or digital stopwatch) do you use, and where do you put it? Where do you keep the charts, approach plates, and scratch paper? How many people write down every clearance, heading, altitude and frequency change? How do you keep from dropping your pen (or pencil)? Is it on a string? Where do you put in when not in use? Velcro? Your pocket? I've read the books, but I just wonder how people cope in real life. Rod Machado talks about using a clipboard (with extra clips on the 3 other sides) in his excellent training manual. This seems like a good idea to me. Steve PP ASEL Instrument student Sounds like great advice to me! I imagine as time goes on it will be easy to become complacent. This sounds like a good way to guard against that! |
On Feb 18, 8:33 pm, wrote:
What methods do you deploy? How many folks use a kneeboard? What kind of timer (analog or digital stopwatch) do you use, and where do you put it? Where do you keep the charts, approach plates, and scratch paper? How many people write down every clearance, heading, altitude and frequency change? How do you keep from dropping your pen (or pencil)? Is it on a string? Where do you put in when not in use? Velcro? Your pocket? I've read the books, but I just wonder how people cope in real life. Rod Machado talks about using a clipboard (with extra clips on the 3 other sides) in his excellent training manual. This seems like a good idea to me. Steve PP ASEL Instrument student Thanks to everyone who offered up so many great ideas! This seems to be a very individual thing, but it's great to have so many workable ideas to choose from. I've only been posting for less than a week, but I have found this group to be invaluable! It's amazing to me that so many folks with common interests are willing to provide thoughtful responses to a perfect stranger (me)! I really appreciate it! |
It's not just you, we post because we learn from each other as well.
You're a low time pilot seeing things with unbiased eyes so you may see thigs others of us have overlooked. Post your comments about your discoveries, you may help some of us learn from your experiences. On Feb 20, 8:59 am, wrote: On Feb 18, 8:33 pm, wrote: What methods do you deploy? How many folks use a kneeboard? What kind of timer (analog or digital stopwatch) do you use, and where do you put it? Where do you keep the charts, approach plates, and scratch paper? How many people write down every clearance, heading, altitude and frequency change? How do you keep from dropping your pen (or pencil)? Is it on a string? Where do you put in when not in use? Velcro? Your pocket? I've read the books, but I just wonder how people cope in real life. Rod Machado talks about using a clipboard (with extra clips on the 3 other sides) in his excellent training manual. This seems like a good idea to me. Steve PP ASEL Instrument student Thanks to everyone who offered up so many great ideas! This seems to be a very individual thing, but it's great to have so many workable ideas to choose from. I've only been posting for less than a week, but I have found this group to be invaluable! It's amazing to me that so many folks with common interests are willing to provide thoughtful responses to a perfect stranger (me)! I really appreciate it!- Hide quoted text - - Show quoted text - |
Flight over water...required equipment? | ET | Piloting | 14 | March 27th 06 11:47 PM |
Aerial PHotography Flights 'Required' to File Flight Plans | C J Campbell | Piloting | 15 | December 6th 04 02:17 PM |
Horsepower required for level flight question... | BllFs6 | Home Built | 17 | March 30th 04 12:18 AM |
Is there a FAA Manual for Heli flight examiners? gps required? | Eric D | Rotorcraft | 2 | October 29th 03 11:34 AM |
Is there a FAA Manual for Heli flight examiners? gps required? | Eric D | Rotorcraft | 1 | October 21st 03 04:38 PM |
