Is there a FAA Manual for Heli flight examiners? gps required?
Old October 21st 03, 10:46 PM
Eric D
Default Is there a FAA Manual for Heli flight examiners? gps required?
GPS: If a piece of equipment is installed in the machine that will
be used in a checkride the PIC must know its functionality and be able
to demonstrate its use. For a private checkride there's no requirement
to know GPS use unless its installed and not marked inop before the
ride. Knowledge of Pilotage and Dead Reckoning is probably a far more
important skill to be able to demonstrate.
Bart
Thanks for the info Bart. The reason for the question on the gps, one
of the two instructors he flies with is telling him that gps is
required equipment for the check ride. The Robinson R22 he flies and
would like to use for the checkride does not have gps. Has something
since 9-11 changed that now requires it?
Eric D
Old October 28th 03, 08:27 PM
Barry
There is no requirement for use of a GPS on any FAA Private or Commercial
check ride. However, PTS Task VII(B) Radio Navigation and Radar Services,
is a required flight operation on the practical test. In order to be
evaluated on that task, the aircraft MUST be equipped with either a VOR
receiver, GPS receiver or Loran receiver. You may download the relevant
Practical Test Standard at: http://afs600.faa.gov.
If the helicopter to be used for the check ride is not equipped with a VOR
receiver, then it must be equipped with one of the other forms of electronic
navigation sufficient to demonstrate the navigation task as required on the
Practical Test Standard.
Recently, FAA Headquarters in Washington changed its position on the use of
hand-held VOR and GPS receivers for FAA check rides and is now allowing use
of them on the FAA check ride if certain requirements are met. On the
above-referenced web site, click on "Part 61 Frequently Asked Questions" and
search for "GPS" and you will find all you need to know about its use on FAA
check rides. Use of hand-held VORs are also addressed in the same section.
Lastly, FAA Order 8710-3C Pilot Examiner's Handbook is also available
online. The above web site will contain a link to find it. It's fairly
large to download and somewhat out of date, but available free, should you
wish to look at it. Hope this helps. Tailwinds, - Antique Examiner
"Eric D" wrote in message
om...
Bart
Eric D
Old October 29th 03, 11:34 AM
Eric D
Thank you! This is just what I was looking for. I will pass it on to my friend.
Thanks again!
Eric D
Canadian IFR/VFR Flight Plan gwengler Piloting 3 August 9th 04 08:39 PM
x-43 Flight Garrison Hilliard Military Aviation 0 March 26th 04 12:42 PM
100 years of flight - Special coverage by The Cincinnati Enquirer Garrison Hilliard Military Aviation 1 March 14th 04 02:42 PM
The cost sharing - reimbursment - flight for hire mess Roger Long Piloting 18 October 21st 03 03:12 PM
