Thanks Marcel, but I did try that. No luck ...
Tuno wrote:
Thanks Marcel, but I did try that. No luck ... This is all for US contest rules in 2006... For start cylinder, check "move origin", and uncheck "reduce leg distance" in Task Properties - Observation Zone Tab. Set Radius 1 to correct value for task and Angle1 to 180 degrees. Put in max altitude if applicable, but SeeYou will not check the 2 minute below the start height rule. Same OZ setup for a finish cylinder. In Task Properties - Options set the task type to Assigned Areas task, even for an assigned speed task. Under task distance calculation pick use flight fixes. Under Tools-Options-General under distance calculation, you need to select "using FAI spheroid (CIVL)". Works for all the Turf 06 tasks I looked at in SeeYou within a couple hundredths of a mile. -Dave |
Dave,
I put all those settings in exactly as you described but I still get different answers: Official contest result, day 1: 219.88 miles, 81.59 mph. (No penalties) SeeYou result: 222.4 miles, 82.53 mph. The IGC file is 65tC40R1.igc, it can be downloaded at the SSA contest results page. My SeeYou version is 3.61 ... -ted |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
New DMSt task: 4 TPs | Klaus T. | Soaring | 0 | January 9th 06 12:03 AM |
1000k comp task | Mel Dawson | Soaring | 0 | July 5th 05 08:22 PM |
SeeYou to LX7000 Waypoint Task Files | Ken Kochanski (KK) | Soaring | 1 | May 28th 05 12:22 AM |
New Task | JJ Sinclair | Soaring | 5 | October 23rd 03 01:36 AM |
