JPI Data Question
Old February 20th 07, 07:44 PM posted to rec.aviation.owning
Jim B
Default JPI Data Question
After seeing dozens of turbine twins and singles during the last week, they
had my mouth watering also. My aerial applicator is currently converting a
Air Tractor 301 to a 401-B w/ PT6, this will be his 3rd PT6 AirTractor and
he loves them, even though when maintenance is finally required, it is more
costly, the bills come much less frequently.
"Ronnie" wrote in message
et...
I don't know about you, but all this data from recip engines
reminds me that I really want a turbine powered airplane, with
the simple and smooth operation they provide.
Too bad they are soooo danged expensive.
Ronnie
"Jim B" wrote in message
"Kyle Boatright" wrote in message
How about an intermittent leak on the induction tube on that cylinder?
I
could see a slightly lean mixture resulting in the behavior you noted.
That seems to make sense and something I'll check.
Thanks
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 05:09 PM
FAA ATA-100 data source Paul Tomblin General Aviation 0 November 23rd 06 04:08 PM
AMT question: Approved Data Mark Home Built 16 March 30th 06 04:08 AM
Mfg Data Plate Question Carl Orton Owning 9 November 6th 03 12:12 AM
