SeeYou task settings
Old February 21st 07, 01:36 PM posted to rec.aviation.soaring
ZL
Default SeeYou task settings
Tuno wrote:
Thanks Marcel, but I did try that. No luck ...
This is all for US contest rules in 2006...
For start cylinder, check "move origin", and uncheck "reduce leg
distance" in Task Properties - Observation Zone Tab. Set Radius 1 to
correct value for task and Angle1 to 180 degrees. Put in max altitude if
applicable, but SeeYou will not check the 2 minute below the start
height rule.
Same OZ setup for a finish cylinder.
In Task Properties - Options set the task type to Assigned Areas task,
even for an assigned speed task. Under task distance calculation pick
use flight fixes.
Under Tools-Options-General under distance calculation, you need to
select "using FAI spheroid (CIVL)".
Works for all the Turf 06 tasks I looked at in SeeYou within a couple
hundredths of a mile.
-Dave
Old February 21st 07, 04:03 PM posted to rec.aviation.soaring
Tuno
Dave,
I put all those settings in exactly as you described but I still get
different answers:
Official contest result, day 1: 219.88 miles, 81.59 mph. (No
penalties)
SeeYou result: 222.4 miles, 82.53 mph.
The IGC file is 65tC40R1.igc, it can be downloaded at the SSA contest
results page.
My SeeYou version is 3.61 ...
-ted
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
New DMSt task: 4 TPs Klaus T. Soaring 0 January 9th 06 12:03 AM
1000k comp task Mel Dawson Soaring 0 July 5th 05 08:22 PM
SeeYou to LX7000 Waypoint Task Files Ken Kochanski (KK) Soaring 1 May 28th 05 12:22 AM
New Task JJ Sinclair Soaring 5 October 23rd 03 01:36 AM
