Low fuel emergency in DFW
Old February 23rd 07, 10:47 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default Low fuel emergency in DFW
Danny Deger wrote:
"Ross" wrote in message
Steven P. McNicoll wrote:
"Mike Schumann" wrote in message
I'm not saying that ATC didn't have a problem, but by the same
token, it is also unacceptable for the pilot to continue to his
destination after he declared an emergency to avoid the delays and
hassles of diverting to a closer airport.
What closer airport?
The Dallas news said McKinney (KTKI) and Addison (KADS) were other
choices. As someone else said, the decent cruise to KDFW would have
been just as quick.
This brings up an interesting question. Maybe a straight-in to the
south was not a problem for these other airports, but a straight-in
to the south at DFW was a pain in the ass for DFW traffic. Does ATC
have the right to decline a straight-in to DFW if they can give the
pilot a reasonable alternative?
No
Old February 23rd 07, 11:07 PM posted to rec.aviation.piloting
Mike Schumann
If the pilot wants a straight in approach to a runway that is occupied by
another aircraft that can't be moved in time, ATC can certainly suggest
alternatives as well as point out the impossibility of the pilot's request.
This isn't a legal issue. This is a question of declaring an emergency and
then having the pilot and ATC work together to safely get the aircraft down
at an acceptable airport ASAP.
I don't know all of the details. It does appear that ATC was reluctant to
totally screw up their arrival patterns at DFW to handle this aircraft.
That would obviously not be acceptable if DFW was the only option. However,
the pilot also appears to have been focused on getting home more than his
"emergency". Gethomeitis is what kills the most pilots every year.
Mike Schumann
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
been just as quick.
No
Posted via a free Usenet account from http://www.teranews.com
Old February 24th 07, 12:06 AM posted to rec.aviation.piloting
Morgans[_2_]
request.
It has been reported here, that he asked for the emergency 17 straight in,
82 miles away. Plenty of time to vacate the runway and move any other
aircraft in his path.
Jim in NC
Old February 24th 07, 01:03 AM posted to rec.aviation.piloting
Steven P. McNicoll
request.
That wasn't the case here.
Old February 24th 07, 06:24 AM posted to rec.aviation.piloting
C J Campbell
On Fri, 23 Feb 2007 15:07:14 -0800, Mike Schumann wrote
(in article ):
There were no other aircraft on the runway that could not move in time. The
argument is a red herring. ATC is required to comply with the pilot's
emergency request. The time to settle whether that request was reasonable or
not is on the ground. But ATC must comply.
Rule #1 of aviation: The airplane has a Pilot in Command. The airplane is not
flown by a committee or by an anonymous voice on the ground. It is not a
democracy.
It appears here that ATC wanted to avoid departure delays even if it meant
killing people. The pilot has a responsibility to his passengers, not to
complying with ATC stupidity. The pilot failed in that responsibility, but
managed to live anyway. He might not be so lucky next time.
ATC will kill you given half a chance. It is the pilot's responsibility to
see to it that that does not happen.
Waddling Eagle
World Famous Flight Instructor
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
