ATC Handling of Low-Fuel American Flight
Old February 24th 07, 02:55 PM posted to rec.aviation.ifr
Sam Spade
Default ATC Handling of Low-Fuel American Flight
Steven P. McNicoll wrote:
"Sam Spade" wrote in message
You are absolutely correct. Airline pilots, as a group, tend to be the
worst about this because of subtle company intimidation.
ATC could have very well taken this as a declaration of minimum fuel,
which is NOT a declaration of emergency.
The magig words are, "American 123 is declaring an emergency." ATC
response, "American 123 what is the nature of your emergency?" And, then
the trolly is on the track.
If ATC fails to respond to that properly and gives the run around, the
pilot should then be resourceful to get them to understand they will give
him what he needs. "Mayday, mayday, mayday" is one option that hopefully
should not be needed.
"We need to declare an emergency," a pilot radioed air traffic control. "We
got a low fuel situation. We're not sure if it's a fuel leak or what, but we
need to get on the ground, right away, please."
I still think the imperative has to be stated, rather than what can be
taken as future intent.
"We need to..." clouds the issue. "American 123 is declaring an
emergency." Then, let ATC respond. If the response is unsatisfactory;
i.e., "What is the nature of your emegency American 123?, then the PIC
should take additional direct action.
It is not the time for brevity or inferences. The crew started out
okay, but absolutely did not follow through.
Old February 24th 07, 02:58 PM posted to rec.aviation.ifr
Steven P. McNicoll
It is not the time for brevity or inferences. The crew started out okay,
The crew declared an emergency situation with that statement.
Old February 24th 07, 03:37 PM posted to rec.aviation.ifr
John R. Copeland
"Sam Spade" wrote in message ...
No part of "need" sounds wishy-washy to me.
According to the quote above, the pilot *twice* said "need".
Old February 24th 07, 03:52 PM posted to rec.aviation.ifr
Sam Spade
Nonetheless, it turned out "wishy-washy, didn't it.
Old February 24th 07, 04:02 PM posted to rec.aviation.ifr
Matt Whiting
control. "We got a low fuel situation. We're not sure if it's a fuel
leak or what, but we need to get on the ground, right away, please."
be taken as future intent.
Only because of an incompetent controller. The words used by the pilot
wouldn't have changed that.
Matt
Old February 24th 07, 04:34 PM posted to rec.aviation.ifr
Sam Spade
fuel leak or what, but we need to get on the ground, right away,
please."
We seriously disagree on that one.
Old February 24th 07, 10:27 PM posted to rec.aviation.ifr
Steven P. McNicoll
No.
Old February 25th 07, 02:06 AM posted to rec.aviation.ifr
Sam Spade
No.
Since he did not get the runway he *should have demanded* why did it not
turn out "wishy-washy?"
Old February 25th 07, 03:04 AM posted to rec.aviation.ifr
Steven P. McNicoll
The declaration was not wishy-washy.
Old February 25th 07, 01:08 PM posted to rec.aviation.ifr
Sam Spade
Agreed. But, he needed to continue to be agressive given the
circumstances, and he did not.
Handling Characteristics of the Flight Design CTSW John Piloting 9 March 14th 07 03:38 AM
American Flight 191 - Recovery Procedure Rick Umali Piloting 17 November 5th 06 03:35 AM
Angel Flight fuel discounts John Doe Piloting 4 January 20th 06 01:24 PM
Passenger attempts to hijack American Eagles flight C J Campbell Piloting 5 January 11th 04 04:04 PM
American Safety Flight Systems seat belts -- Help! Paul Millner Owning 1 July 7th 03 10:10 PM
