That is not an option for all the other airplanes or ATC.
Yes it it. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
Which law, rule or regulation allows near mid-air collisions
because one aircraft has a cob up their ass? "Jose" wrote in message . .. | That is not an option for all the other airplanes or ATC. | | Yes it it. | | Jose | -- | Humans are pack animals. Above all things, they have a deep need to | follow something, be it a leader, a creed, or a mob. Whosoever fully | understands this holds the world in his hands. | for Email, make the obvious change in the address. |
"Jim Macklin" writes:
Which law, rule or regulation allows near mid-air collisions because one aircraft has a cob up their ass? None. But the law allows anything for an aircraft in an emergency. Near-midair collisions are not a risk, anyway. -- Transpose mxsmanic and gmail to reach me by e-mail. |
because one aircraft has a cob up their ass? The one that gives an emergency aircraft priority over all other aircraft. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
No, it does not, it gives the PIC the legal authority to
deviate from any law, rule or clearance GIVEN by ATC pr the FAA. It does not allow the PIC to justify causing an accident. ATCs job in an emergency is to think straight and get the PIC priority service and on the ground ASAP within the bounds of possibilities. Think about the movie Airport, that had a snow covered runway, a stuck plane on a runway and noise complaints. Dean Martin as PIC was demanding clearance to the runway that was blocked. ATC doesn't have authority to physically clear a runway, that was about the only accurate part of that movie. Priority does not mean ATC will build a runway in 30 seconds so you can land. "Jose" wrote in message t... | Which law, rule or regulation allows near mid-air collisions | because one aircraft has a cob up their ass? | | The one that gives an emergency aircraft priority over all other aircraft. | | Jose | -- | Humans are pack animals. Above all things, they have a deep need to | follow something, be it a leader, a creed, or a mob. Whosoever fully | understands this holds the world in his hands. | for Email, make the obvious change in the address. |
![]() "Jim Macklin" wrote in message ... ATCs job in an emergency is to think straight and get the PIC priority service and on the ground ASAP within the bounds of possibilities. In this case they did neither. Think about the movie Airport, that had a snow covered runway, a stuck plane on a runway and noise complaints. Dean Martin as PIC was demanding clearance to the runway that was blocked. ATC doesn't have authority to physically clear a runway, that was about the only accurate part of that movie. No, ATC doesn't. But there are people with that authority and Burt Lancaster had ordered the snow plows to push the 707 off the runway if George Kennedy wasn't able to move it by more conventional means before the emergency aircraft arrived. Actually, "Airport" was pretty accurate, far better than it's sequels which went progressively from bad to bizarre. Priority does not mean ATC will build a runway in 30 seconds so you can land. No, it means ATC will give an aircraft in distress the right of way over all other air traffic. They didn't do that in this case, that's the error. |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
