ATC Handling of Low-Fuel American Flight
Old February 26th 07, 12:03 AM posted to rec.aviation.ifr
Jim Macklin
Default ATC Handling of Low-Fuel American Flight
The point is that declaring an emergency does not require
ATC to do the impossible or grant every deviation. 91.3
does allow the pilot to deviate without a clearance if
necessary.
Giving priority handling does not mean or require doing
everything the pilots asks. It does mean that ATC won't
vector you the normal 20 mile base leg and they will fit you
in ASAP. There are priorities...
"Matt Whiting" wrote in message
| Jim Macklin wrote:
| Right of way DOES NOT mean carte blanche, see
| 2-1-1. ATC SERVICE
| The primary purpose of the ATC system is to
prevent a
| collision between aircraft operating in the system and
to
| organize and expedite the flow of traffic. In addition
to
| its primary function, the ATC system has the capability
to
| provide (with certain limitations) additional services.
The
| ability to provide additional services is limited by
many
| factors, such as the volume of traffic, frequency
| congestion, quality of radar, controller workload,
higher
| priority duties, and the pure physical inability to scan
and
| detect those situations that fall in this category. It
is
| recognized that these services cannot be provided in
cases
| in which the provision of services is precluded by the
above
| factors. Consistent with the aforementioned conditions,
| controllers shall provide additional service procedures
to
| the extent permitted by higher priority duties and other
| circumstances. The provision of additional services is
not
| optional on the part of the controller, but rather is
| required when the work situation permits. Provide air
| traffic control service in accordance with the
procedures
| and minima in this order except when:
| No document I have found says that declaring EMERGENCY
means
| ATC shall grant any pilot request, those requests have
| limitations due to traffic and other events. Right of
way
| and priority handling does not mean that every PIC
request,
| demand or wish can, will or should be granted.
| Handling a flight with an emergency isn't an "additional
service" as
| defined here. This is talking about optional services
like VFR
| advisories, not dealing with an emergency.
| Matt
Old February 26th 07, 12:39 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Jim Macklin" wrote in message
necessary.
ATC wasn't asked to do the impossible.
Old February 26th 07, 03:08 AM posted to rec.aviation.ifr
Jim Macklin
That may be true, but it isn't what this group decides now,
or even what the FAA decides tomorrow, but what did the
controller think he could do.
If he needs more training, so bet it, but I won't condemn
either the controller or the pilot based solely on a TV
edited report.
"Steven P. McNicoll" wrote in
message
nk.net...
| "Jim Macklin" wrote
in message
require
| necessary.
Old February 26th 07, 03:35 AM posted to rec.aviation.ifr
Steven P. McNicoll
edited report.
You said you hadn't seen the report, what were you basing your argument on?
Old February 26th 07, 07:51 AM posted to rec.aviation.ifr
Jim Macklin
50 years of reading and watch news reports.
message
nk.net...
| "Jim Macklin" wrote
in message
now,
condemn
| edited report.
your argument on?
Handling Characteristics of the Flight Design CTSW John Piloting 9 March 14th 07 03:38 AM
American Flight 191 - Recovery Procedure Rick Umali Piloting 17 November 5th 06 03:35 AM
Angel Flight fuel discounts John Doe Piloting 4 January 20th 06 01:24 PM
Passenger attempts to hijack American Eagles flight C J Campbell Piloting 5 January 11th 04 04:04 PM
American Safety Flight Systems seat belts -- Help! Paul Millner Owning 1 July 7th 03 10:10 PM
