Thanks both Tauno and ktbr.
Second question. After we returned home, I swapped the KX155's returning them to the original slots. #1 KX155 (the wet one) didn't give us any pitching problem with the auto pilot, however, thinking of coax, conection, or antenna problems, we had a local tower operator complain about very staticy transmisions. Reception was fine, Nav functions were fine. #2 transmitted much better however only #1 is coupled so we couldn't check the #2 radio/tray/coax/antenna against the autopilot. Next step to swap coax antenna leads? Thanks again, Jim |
As I stated, if the coax is old (I'm talking like 10.. 15 or more)
years... just replace it. I don;t think I'd waste a lot of time trying to troubleshoot old coax. Don't forget about the balun to the NAV antenna, it can get lossy when old and degrade NAV reception. A high VSWR can ultimately damage the transmitter as well, since that reflected power if coming back into the RF power stage where it will increase the operating temperature and ultimately cause failure. Jim B wrote: Thanks both Tauno and ktbr. Second question. After we returned home, I swapped the KX155's returning them to the original slots. #1 KX155 (the wet one) didn't give us any pitching problem with the auto pilot, however, thinking of coax, conection, or antenna problems, we had a local tower operator complain about very staticy transmisions. Reception was fine, Nav functions were fine. #2 transmitted much better however only #1 is coupled so we couldn't check the #2 radio/tray/coax/antenna against the autopilot. Next step to swap coax antenna leads? Thanks again, Jim |
Replacing the coax will have to wait until annual time when we can pull the
interior and the headliner. We're planning on changing the headliner anyway, so the ceiling will be open at that time. Meanwhile we'll keep a record of what occurs, swap antennas, and try to follow the problem. Thanks Jim |
Also check that the radio is going ALL the way in. The lip on the rack
should tocuch the faceplate. Sometimes the faceplate is hitting the mounting rails and not going ALL the in and the atenna connector is make a poor connection. On Feb 26, 10:52�am, "Jim B" wrote: Replacing the coax will have to wait until annual time when we can pull the interior and the headliner. *We're planning on changing the headliner anyway, so the ceiling will be open at that time. *Meanwhile we'll keep a record of what occurs, swap antennas, and try to follow the problem. Thanks Jim |
Jim B wrote:
Thanks both Tauno and ktbr. Second question. After we returned home, I swapped the KX155's returning them to the original slots. #1 KX155 (the wet one) didn't give us any pitching problem with the auto pilot, however, thinking of coax, conection, or antenna problems, we had a local tower operator complain about very staticy transmisions. Reception was fine, Nav functions were fine. #2 transmitted much better however only #1 is coupled so we couldn't check the #2 radio/tray/coax/antenna against the autopilot. Next step to swap coax antenna leads? Thanks again, Jim You should take the wet (and now hopefully dry again) unit to a shop for a checkout. Swimming can create weird effects in electronics. I once repaired a handheld COM, which had been diving, and all the glass-tube diodes were broken, as electrolytic corrosion ate the wire at the more positive end, and water got into the glass encapsulation. -- Tauno Voipio (PA28RT-201T, OH-PYM) tauno voipio (at) iki fi |
Standing room only ~ Is this a joke? | Flyingmonk | Piloting | 7 | April 27th 06 06:20 PM |
Another CLUSTER Fu*k by Thousands Standing Around | Whatdoyouexpect | Instrument Flight Rules | 0 | March 18th 06 03:28 PM |
Another CLUSTER Fu*k by Thousands Standing Around | Whatdoyouexpect | Piloting | 0 | March 18th 06 03:27 PM |
Voltage Standing Wave Ratio Bridge | SUIRE2 | Home Built | 1 | February 9th 06 03:10 PM |
American Airlines - Last one standing | Larry Dighera | Piloting | 42 | September 17th 05 04:50 AM |
