Tauno Voipio wrote:
The ratio of voltage and current of a RF signal in a transmission line (called characteristic impedance) is fixed and determined by the dimensions and materials of the transmission line. Considering how much abuse the typical piece of coax absorbs over GOK how many years of being scrunched into the rats nest of wiring behind most GA panels, I suspect the characteristic impedance is anything but fixed. Not to mention that a lot of radio guys barely know which end of a soldering iron to pick up. SWR Meter? That's the box which tells you how ****ty a job you did of putting the connectors on before you button up the panel and write out the customer's bill. |
Roy Smith wrote:
Tauno Voipio wrote: The ratio of voltage and current of a RF signal in a transmission line (called characteristic impedance) is fixed and determined by the dimensions and materials of the transmission line. Considering how much abuse the typical piece of coax absorbs over GOK how many years of being scrunched into the rats nest of wiring behind most GA panels, I suspect the characteristic impedance is anything but fixed. As long as the scrunch is short compared to the wavelength (in the cable, for coax about 2/3 of free-space wavelength), the signal could not care less, and, for practical purposes, the characteristic impedance is constant. If we have to take the attenuation into account, the impedance is not even real, but complex, containing capacitive or inductive components. Not to mention that a lot of radio guys barely know which end of a soldering iron to pick up. SWR Meter? That's the box which tells you how ****ty a job you did of putting the connectors on before you button up the panel and write out the customer's bill. You can also crash a new car before delivering it to the customer ... -- Tauno Voipio tauno voipio (at) iki fi |
Standing room only ~ Is this a joke? | Flyingmonk | Piloting | 7 | April 27th 06 06:20 PM |
Another CLUSTER Fu*k by Thousands Standing Around | Whatdoyouexpect | Instrument Flight Rules | 0 | March 18th 06 03:28 PM |
Another CLUSTER Fu*k by Thousands Standing Around | Whatdoyouexpect | Piloting | 0 | March 18th 06 03:27 PM |
Voltage Standing Wave Ratio Bridge | SUIRE2 | Home Built | 1 | February 9th 06 03:10 PM |
American Airlines - Last one standing | Larry Dighera | Piloting | 42 | September 17th 05 04:50 AM |
