![]() "Matt Whiting" wrote This isn't true with chain saws. The biggest problem is that after a couple of years, especially if not used frequently, the cheap saws tend to get very hard to start. My Stihl often sits a year between uses as I tend to cut and split 7-10 cord each year all in one month or so, yet it still fires up in 3-5 pulls. Things change, over the years. It is impossible to justify buying a saw at three times the cost, when you can get a decent saw that will start reliably. I have a Pouland that gets one or two tanks run through it, every year, or sometimes two. It is around 6 years old, and I can guarantee that I could go out to the cold shed, put fresh gas in it, and it would start on the third pull. Not everyone needs a lumberjack saw. That's the facts. -- Jim in NC |
("Morgans" wrote)
Not everyone needs a lumberjack saw. That's the facts. But if he's got a lumberjack saw, ...he's ok? g Montyblack |
Be safe, if you are using a chainsaw on ice covered ground,
have spikes on your boots. Kevlar chaps and hearing and eye protection, too. If you only have a few trees, an axe will get the job done and keep Al Gore happy [if that matters]. "Montblack" wrote in message ... | ("Morgans" wrote) | Not everyone needs a lumberjack saw. That's the facts. | | | But if he's got a lumberjack saw, ...he's ok? g | | | Montyblack | | |
Jim Macklin wrote:
Be safe, if you are using a chainsaw on ice covered ground, have spikes on your boots. Kevlar chaps and hearing and eye protection, too. Absolutely. Chainsaws are amazing tools, but also can cause amazing damage given one second of complacency. If you only have a few trees, an axe will get the job done and keep Al Gore happy [if that matters]. Axes are nearly as danagerous as chain saws, especially in the hands of a person who uses an axe once a year or so. And if using my chain saw bothers Algore, I'll go out and fire it up right now! :-) Matt |
damage given one second of complacency. I know. After years of working with woodworking tools (routers, planers, table saws, etc.) I've developed a remarkable respect for whirling metal things. My 16 year old son begged me to let him try the chain saw, and I eventually relented -- but not till after a 10 minute lecture on safety. He did fine -- but it was like watching Mary sky-dive... Not good for the digestion. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Matt Whiting" wrote Absolutely. Chainsaws are amazing tools, but also can cause amazing damage given one second of complacency. Absolutely positively. I have my own near miss chainsaw story, from long ago. I was standing on a very steep hill, of a 45 degree angle or more. The tree I was cutting down was not that big, but I needed to reposition myself, and stopped cutting and took the saw out of the cut. My complacency was that the saw needed adjusting, and I had to keep jazzing the throttle to keep it running. Big mistake. Of course, the chain keeps going while you are jazzing the throttle. As I repositioned, I suddenly saw orange from my International Orange overalls fly (required aviation content g) into the air. The saw got too close to my leg, but the good thing is that it just touched my clothes, without even getting down to my jeans. Needless to say, I stopped and adjusted the saw. -- Jim in NC |
Axes are dangerous, but if all you're going to do is lop a
few branches and makes some smaller tree trunks light enough to move, and axe can do the job for $20 or so given some time. You also need to be able to swing it. But a dull axe is a real pain to use. It is also dangerous because it can fail to bite and skip off the log and if anyone is close, make a real bad cut or kill them. Lots of room needed. Chain saws need to be sharp too. If you don't control the cut, it can swing into a leg or arm and do a 1 second amputation that will be very hard to put back. The Kevlar vests and leggings are designed jam the chain and stall the saw before it gets to the bone.. And you can get frame or buck saw. It all depends on how much time you want to trade for money. I think more chain saws are ruined by improper chain oiling and the engines are ruined by too much or no oil in the fuel. Also saw dust can block the cooling fins and the saw will over-heat and destroy the piston and warp the head. "Matt Whiting" wrote in message ... | Jim Macklin wrote: | | Be safe, if you are using a chainsaw on ice covered ground, | have spikes on your boots. Kevlar chaps and hearing and eye | protection, too. | | Absolutely. Chainsaws are amazing tools, but also can cause amazing | damage given one second of complacency. | | | If you only have a few trees, an axe will get the job done | and keep Al Gore happy [if that matters]. | | Axes are nearly as danagerous as chain saws, especially in the hands of | a person who uses an axe once a year or so. And if using my chain saw | bothers Algore, I'll go out and fire it up right now! :-) | | Matt |
Montblack wrote:
("Morgans" wrote) Not everyone needs a lumberjack saw. That's the facts. But if he's got a lumberjack saw, ...he's ok? g Montyblack You sure that isn't Mountblack? Matt |
... ("Morgans" wrote) Not everyone needs a lumberjack saw. That's the facts. But if he's got a lumberjack saw, ...he's ok? g He's a lumberjack and he's okay He sleeps all night and he works all day. |
"Matt Barrow" wrote: "Montblack" wrote in message ... ("Morgans" wrote) Not everyone needs a lumberjack saw. That's the facts. But if he's got a lumberjack saw, ...he's ok? g He's a lumberjack and he's okay He sleeps all night and he works all day. He cuts down trees, He eats his lunch, He goes to the lavat'ry |
OSH storm pix | Jay Honeck | Piloting | 19 | August 26th 06 06:34 AM |
Storm Damage | john smith | Piloting | 0 | June 23rd 06 10:05 PM |
Hanger and gliders hit by storm. | [email protected] | Soaring | 6 | February 1st 05 01:44 AM |
F-16I Soufa (Storm) Pics... | robert arndt | Military Aviation | 6 | September 26th 04 12:17 PM |
Storm scope suggestions | B2431 | Home Built | 7 | May 29th 04 01:33 AM |
