ATC Handling of Low-Fuel American Flight
Old March 1st 07, 01:41 AM posted to rec.aviation.ifr
Jim Carter[_1_]
Default ATC Handling of Low-Fuel American Flight
I believe the closest would have been Love based on the point at which he
mentioned the fuel problem. This has already been addressed in this thread
so I suspect you already knew that Matt.
I'm not condoning what ATC did or how they responded, but like the UK pilot
that continued on single-engine across the pond I wonder why AA continued on
past a suitable airport once they knew they had a problem. That's all I'm
questioning.
Jim Carter
Rogers, Arkansas
"Matt Barrow" wrote in message
"Jim Carter" wrote in message
t...
If the aircrew "needed to get on the ground right away", why did they
overfly other suitable airports? That action alone could have suggested
to ATC that this wasn't that big an issue. Love Field has equipment to
deal with air carrier class aircraft and they flew right past it even
after being asked about landing there.
Between Tulsa and DFW, which airports would those be?
Matt Barrow
Performance Homes, LLC
Colorado Springs, CO
Old March 1st 07, 02:09 AM posted to rec.aviation.ifr
Barry
questioning.
In fact, it was a British Airways 747 that continued on three engines, not
one. Here's an interesting column about that the incident:
http://www.avweb.com/news/pelican/193882-1.html
Old March 1st 07, 02:11 AM posted to rec.aviation.ifr
Jim Carter[_1_]
You're right - my mistake.
Jim Carter
Rogers, Arkansas
"Barry" wrote in message
pilot
on
questioning.
Sam Spade
Did you see the plot I posted in a similar thread? DAL and DFW 17C were
the same distance from his position at declaration.
Check the message I left pointing to the graphic, in which I give the
Part 121 perspective.
Old March 1st 07, 02:35 AM posted to rec.aviation.ifr
Jim Carter[_1_]
Just saw it Sam. Nice perspective and probably pretty accurate too. I am no
way advocating that ATC did right, I was just wondering if the actions of
the aircrew might seem inconsistent with their declarations. I'm not sure
that can be answered, but it really shouldn't matter either.
Jim Carter
Rogers, Arkansas
"Sam Spade" wrote in message
thread so I suspect you already knew that Matt.
Check the message I left pointing to the graphic, in which I give the Part
121 perspective.
Old March 1st 07, 09:07 PM posted to rec.aviation.ifr
Steven P. McNicoll
t...
How does the distance to DFW compare to the distance to DAL from that point?
pilot that continued on single-engine across the pond I wonder why AA
continued on past a suitable airport once they knew they had a problem.
That's all I'm questioning.
He continued on with three engines, not one.
Handling Characteristics of the Flight Design CTSW John Piloting 9 March 14th 07 03:38 AM
American Flight 191 - Recovery Procedure Rick Umali Piloting 17 November 5th 06 03:35 AM
Angel Flight fuel discounts John Doe Piloting 4 January 20th 06 01:24 PM
Passenger attempts to hijack American Eagles flight C J Campbell Piloting 5 January 11th 04 04:04 PM
American Safety Flight Systems seat belts -- Help! Paul Millner Owning 1 July 7th 03 10:10 PM
