Ignition switch settings
Old March 4th 07, 04:16 AM posted to rec.aviation.piloting
Morgans[_2_]
Default Ignition switch settings
wrote
I'd rather have the toggles in my Jodel but it makes the
airplane so much easier to steal. If you can get in you can go.
You could rig up a cover to put over the toggles, with a place to put a
padlock on the cover, as long as it is not a certified plane.
Would altering a plane in that manner be against the rules for certified
planes? It would be in the certified plane's regular certified condition,
while it was being flown, after all!
Jim in NC
Old March 4th 07, 01:22 AM posted to rec.aviation.piloting
Travis Marlatte
"Jon Woellhaf" wrote in message
And I've been trying to learn for years why R is on the left and L is on
the right.
My recollection from the last time this was discussed is that the labeles
used to be the other way around so that "L" on the left meant that the left
mag was grounded and, therefore, the right mag was firing. Then, to keep it
more consistent with the "Off" and "Both" labeling, they switched the
labeling but left the right key position which grounded the right mag so
that the left mag was firing now labeled "L"?
Doesn't bother me a bit. If one mag fails an RPM drop, I'm gonna check the
wiring to both any. What is more important to me is that the left key
position has the bottom plugs firing. That's important so that I can pull
the correct plugs the first time to clear an unusually stubborn fouling.
Say, why don't they label them "Off", "B", "T", and "Both"?
Travis
Lake N3094P
PWK
Old March 4th 07, 04:23 AM posted to rec.aviation.piloting
Morgans[_2_]
Excellent suggestion! Why not? It might make too much sense, that way!
One could put an "auxiliary label" on panel next to the "L" and "R" with a
Dyno Label, or with another favorite method, though.
Jim in NC
Old March 4th 07, 07:53 AM posted to rec.aviation.piloting
Jackal24
"Travis Marlatte" wrote in
t:
key position has the bottom plugs firing. That's important so that I
can pull the correct plugs the first time to clear an unusually
stubborn fouling.
I thought that one mag controlled the top plugs on one side and the bottom
on the other side.
Old March 5th 07, 04:40 PM posted to rec.aviation.piloting
On Mar 4, 12:53 am, Jackal24 wrote:
"Travis Marlatte" wrote . net:
stubborn fouling.
on the other side.
Yup, on Lycoming. Continental, at least on the smaller engines,
will have the right mag firing the top plugs and the left firing the
bottom. The impulse mag (right) fires the top plugs, since they're
less likely to get wet with oil or fuel.
Dan
Old March 4th 07, 04:55 PM posted to rec.aviation.piloting
Stubby
Tony Cox wrote:
Here's a question that until yesterday I'd have thought was
obvious.
Cessna-style (and no doubt other) ignition switches have five
settings -- Off/Right/Left/Both/Start. When you're on the "Right"
setting, does it mean you are firing on the right magneto or
does it mean the right magneto is grounded?
Is this covered in the plane's POH?
Old March 4th 07, 05:34 PM posted to rec.aviation.piloting
Tony Cox
On Mar 4, 8:55 am, Stubby
obvious.
Good question. It isn't. It isn't covered in the
shop manual either.
Nav radio settings in FMC Mxsmanic Piloting 5 January 10th 07 08:39 PM
74 Archer ignition switch question Mike Noel Owning 9 September 10th 06 10:46 PM
Ignition switch, what happen when Left or Right is selected Martin B Piloting 41 May 21st 05 04:55 AM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Just Ordered: An Ignition Switch and Oil Filter from ACS Larry Smith Home Built 30 October 22nd 03 07:41 AM
