An actual post related to flying
Old March 3rd 07, 07:42 PM posted to rec.aviation.piloting
Paul Tomblin
Default An actual post related to flying
In a previous article, "Private" said:
they are superior to the Phillips in every way. IIRC there is some real
historical chauvinism that resulted in the use of the Phillips design in the
USA and the rejection of the superior Robertson.
"historical chauvinism" is sometimes spelt "high licensing fees".
Paul Tomblin http://blog.xcski.com/
"Go go Gadget kernel compile!" - Chris "Saundo" Saunderson
Old March 3rd 07, 07:58 PM posted to rec.aviation.piloting
Private
"Paul Tomblin" wrote in message
IIRC this was part of the problem in this case. I suspect that any patent
would have expired by now, but perhaps there is a surviving copyright.
Happy landings,
Old March 3rd 07, 09:18 PM posted to rec.aviation.piloting
Private
"Private" wrote in message
news:urkGh.1219037$R63.505948@pd7urf1no...
Happy landings,
From Wikipedia
http://en.wikipedia.org/wiki/Robertson_screwdriver
http://en.wikipedia.org/wiki/P.L._Robertson
I note that Robertson was having the same kind of legal problems protecting
his invention as the Wrights were having at the same time. Today we realize
that he would perhaps have been smarter to give away the license to use the
screws and to retain the license for the drivers.
Also of interest and on topic
http://en.wikipedia.org/wiki/One_Good_Turn
http://en.wikipedia.org/wiki/Phillips_Head
Happy landings,
Old March 4th 07, 03:34 AM posted to rec.aviation.piloting
Morgans[_2_]
protecting his invention as the Wrights were having at the same time.
Today we realize that he would perhaps have been smarter to give away the
license to use the screws and to retain the license for the drivers.
It may be of interest that square drive screws are becoming much more
popular in construction work.
I have used square drive finish screws. Neatest thing since sliced bread,
where it is needed, as in having a 12d finish nail sized hole, but the
ability to pull something together, and hold much better than a nail.
Also, deck screws with a square drive are around. It may be that if there
is still a royalty for using Robertson screws, they got around it in an
innovative way. These screws I am talking about can be driven by a Phillips
head driver (very poorly, though) but have the inside of the Phillips slots
enlarged so that a square drive will fit in it. If you keep a reasonable
amount of pressure on them, they WILL not slip.
I look forward to seeing more and different kinds of hardware showing up
with square drives. I'll switch every one out that I can find!
Jim in NC
Old March 4th 07, 05:18 AM posted to rec.aviation.piloting
Private
"Morgans" wrote in message
"Private" wrote
snip
Phillips head driver (very poorly, though) but have the inside of the
Phillips slots enlarged so that a square drive will fit in it. If you
keep a reasonable amount of pressure on them, they WILL not slip.
Jim in NC
I have not seen this type of decking screws but have been using some
European screws for assembling cabinet boxes that have this type of head.
IIRC they are called 'Conformat' and AFAIK are really designed for particle
board but are great for plywood. They have great clamping force but are not
pointed and do not tend to split the plys when screwed into the endgrain,
they do require a $pecial $tepped drill bit. They have a very sharp but
coarse pitch thread with a large flat landing at the root of the thread,
something like this --^----^----^----^----^-- These screws can also be
driven with either a big Philips or a #2 Robertson.
Old March 3rd 07, 08:55 PM posted to rec.aviation.piloting
Don Tuite
On Sat, 3 Mar 2007 19:42:48 +0000 (UTC),
Have we covered Pozidrive versus Phillips? (Too many mgs to scan.)
Tektronix used Pozidrives exclusively when I was there.
Don
Another aviation related post: eFlyBook pirep Viperdoc Piloting 8 October 27th 06 02:05 PM
An actualy flying related post: eFlyBook Viperdoc Piloting 8 October 18th 06 12:41 PM
RSS feed for glider flying related news and features? Matthieu Soaring 0 November 16th 05 06:05 PM
First approach in actual Wizard of Draws Instrument Flight Rules 28 October 19th 04 06:42 PM
IR without actual IMC Iain Wilson Instrument Flight Rules 26 October 13th 03 11:26 PM
