Flying weather in New York in March
Old March 3rd 07, 11:18 PM posted to rec.aviation.piloting
Jon Woellhaf
Default Flying weather in New York in March
Dan Luke wrote
Wow: initial on-course heading from JFK to SFO is 296.
What fixed compass heading would hold to fly from JFK to SFO (assuming no
wind correction)?
Old March 4th 07, 01:32 AM posted to rec.aviation.piloting
M[_1_]
wind correction)?
Is it a trick math question? It's certain won't be the great circle
route, which has a continuous changing magnetic heading to hold.
Given the difference of magnetic variation between west coast and the
east coast, I'm not certain this can be calculated using a math
formula. Such a magnetic heading can be deduced by a computer
simulation using the brute force method.
Old March 4th 07, 02:00 AM posted to rec.aviation.piloting
Tony Cox
"M" wrote in message news:
wind correction)?
This is a very complex mathematical problem, but it could be
solved analytically if a precise description of the earth's magnetic
field were available. To see how involved it gets, look up "affine
connections" in Wikipedia, but that's just the theory!
A numeric solution by successive approximation would yield
an approximate answer. One would calculate an approximation
to the magnetic field using the dashed magnetic variation lines
on the various sectionals & then extrapolate using (say) one-mile
path lengths. Vary the initial magnetic heading from JFK using
Newton's method until you hit SFO with the desired accuracy.
Well, that's what I'd do were I at all interested..!
Old March 4th 07, 06:00 PM posted to rec.aviation.piloting
Jon Woellhaf
It's not really a trick question, but I think it's a difficult one.
wind correction)?
Old March 5th 07, 01:16 AM posted to rec.aviation.piloting
Judah
"Jon Woellhaf" wrote in
wind correction)?
Actually, I believe there are many right answers, but it largely depends on
how many laps one is willing to make around the globe before finally reaching
SFO...
Old March 5th 07, 08:57 AM posted to rec.aviation.piloting
Tony
If you wanted an approximation, start with a guess. look 50 miles
along that course line, note the deviation and variation at that point
and use it to calculate where you'd be for a 100 mile flight. Repeat
from that point about 30 times until you are abeam SFO. Now, since
that's about a 3000 mile trip, adjust your initial guess by 1 degree
for every 50 miles you're off, then try again. We used to call that
approach a numerical solution, or brute strength calculation, it
probably has a sexier name now.
There's a neat implication here. If you want to arrive within say 10
miles of your target after holding constant heading for 3000, your
heading has to really really be constant -- like to the tune of arc
tan (10/3000) or 0.2 degrees. That's a really tight tolerance to hold
on average.
Remember Linburgh arriving over Ireland within a few miles of where he
intended, after crossing the ocean? Lucky Lindy indeed!
going On Mar 4, 1:00 pm, "Jon Woellhaf"
wind correction)?
simulation using the brute force method.- Hide quoted text -
- Show quoted text -
Weather during Cirrus crash in New York City Owen Piloting 2 October 12th 06 05:17 AM
FREE Aviation Weather eLearning Session - March 21st scottd Aviation Marketplace 0 March 3rd 06 06:05 PM
Flying into JFK Airport (New York City) - Looking for advice Peter R. Piloting 8 September 23rd 05 06:12 PM
FA: FAIR-WEATHER FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
