ILS sans identification
Old March 5th 07, 02:15 PM posted to rec.aviation.ifr
Ron Natalie
Default ILS sans identification
Jim Macklin wrote:
The FAA removes the ID when the radio facility is out of
tolerance and "not in service" even though there may be a
signal being broadcast [maybe part of testing or trouble
shooting/repair] so it is my practice to have the audio on
at low volume. The monitoring decoding by the hardware is
very nice.
The TEST case brings to mind an amusing story. I was in the
backseat while my wife and her instructor were flying around
trying to track the EMI VOR. They had the IDENT volume up
so I could hear it sending. I finally had pity on them
and let them know it was sending TEST. Shame on Margy, she's
a HAM radio operator from the days when she had to copy CW
at more than twice the rate the VOR sends to get her license.
Old March 5th 07, 05:10 PM posted to rec.aviation.ifr
Tauno Voipio
Ron Natalie wrote:
Jim Macklin wrote:
The FAA removes the ID when the radio facility is out of tolerance and
"not in service" even though there may be a signal being broadcast
[maybe part of testing or trouble shooting/repair] so it is my
practice to have the audio on at low volume. The monitoring decoding
by the hardware is very nice.
But just that's the problem - the ID's are so slow that
the thoughts slip to something else before decoding the code.
When you're really good with Morse, the slow speeds with
proper spacing start to be difficult to listen to.
Tauno Voipio (CPL(a), also OH2UG)
tauno voipio (at) iki fi
Old March 7th 07, 03:40 PM posted to rec.aviation.ifr
The Instrument rating PTS in section VI.B - (Precision approaches)
says:
"9. Selects, tunes, identifies, and monitors the operational status of
ground and airplane navigation equipment used for the approach."
So at least on checkrides you have a reference...
Ed
Old March 9th 07, 04:23 PM posted to rec.aviation.ifr
On Mar 7, 5:51 pm, Mark Hansen wrote:
Yes. It seems about half the people on this thread thought the question
was whether or not you needed to identify the station, and not do you
need to identify by listening to the morse code, or can you just read
the station ID on the avionics gear.
"Anyone have a reference for a requirement to identify an ils or vor
prior to it's use in the USA?
Secondly, is there any reference to the type of identification
required? For example, would checking that the primary flight display
is displaying the correct identifier suffice? Or is there a
stipulation for morse code audible type of identification?
Stan"
Perhaps because both questions were asked.
Stan
Old March 9th 07, 06:27 PM posted to rec.aviation.ifr
Robert Chambers
It's the same for doing a VOR approach, do you keep the NAV button on
with the ident turned to an unobtrusive level while you are shooting the
approach? If the Morse code goes away it's a clue that the navaid my be
unreliable. Same thing for the ILS.
As for identifying PRIOR to use, that's a no brainer. It will get you
in trouble in an instrument ride if you DON'T identify a navaid when you
want to use it.
Stan"
Stan
A-4F cockpit, sans seat Dave Kearton Aviation Photos 1 March 2nd 07 02:13 PM
antenna identification Matt Whiting Piloting 10 December 30th 06 03:47 AM
Identification test Rich S. Home Built 7 June 11th 06 08:00 AM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
