![]() "Mxsmanic" wrote in message ... What aspects of slow-speed or minimum-speed flight should I practice? I've managed to fly for indefinite periods at just above stall speed, straight and level and in standard-rate turns, holding altitude steady. I've managed to do this both with full flaps and no flaps, gear extended and retracted. What things should I try at these low speeds? The aircraft (Baron 58, in this case) seems very unstable at low speeds. I've read that maintaining altitude via the VSI is a bad idea, and that it leads to "chasing the VSI." I almost never look at the VSI unless I absolutely need a specific rate of climb or descent. Usually I just watch the altimeter instead; when it starts to move, I adjust to compensate. Is this a good or bad idea when trying to hold altitude? What about for climbs and descents? Apart from an ILS approach, why would I need to care about a specific rate of descent, especially if I have visual indicators on the runway telling me whether or not I'm on the glide path? I've heard that being below the glide slope is a bad thing that examiners don't like. But if you are far enough out, you're always below the glide slope. At what distance from the airport (or in what configuration) am I expected to stay on or above the glide slope? And does being above the glide slope count strongly against me? If I am flying by hand, how well should I be able to hold altitude in level flight? I'm not talking about regulatory restrictions, I'm talking about how well a decent pilot should be able to do this. Within 100 feet? Fifty feet? Five feet? And I mean without trimming first. What about when making a turn? How steeply should I be able to turn coordinated and without losing altitude? I can do standard turns well enough, but how much steeper do I have to go? -- BLAH BLAH BLAH. Hope this helps. -------------------------------------------- DW |
... What aspects of slow-speed or minimum-speed flight should I practice? Same as normal flight, climbs, descents, turns, straight and level. The aircraft (Baron 58, in this case) seems very unstable at low speeds. Welcome to reduced slipstream and being behind the power curve. Is this a good or bad idea when trying to hold altitude? What about for climbs and descents? Good, unless you happen to have an instantaneous VSI. Apart from an ILS approach, why would I need to care about a specific rate of descent, especially if I have visual indicators on the runway telling me whether or not I'm on the glide path? VFR? Doesn't matter, as long as you don't fly below the slope. I've heard that being below the glide slope is a bad thing that examiners don't like. Your landing gear and the trees on approach will have nasty things to say to you, too. At what distance from the airport (or in what configuration) am I expected to stay on or above the glide slope? And does being above the glide slope count strongly against me? When you make the final descent to landing. And typically no, as most slope indications are set for 3*, while a more normal GA approach is something like 4*. As long as you make the runway touchdown point, it doesn't matter if you flew the approach upside down. If I am flying by hand, how well should I be able to hold altitude in level flight? Better than you can right now. It's always up for improvement. how well a decent pilot should be able to do this. And I mean without trimming first. What about when making a turn? Nonsensical, since a decent pilot would already be trimming by the time he reached his intended altitude (starting at the level-off height). A decent pilot can hold +/- 50 foot. A good pilot can hold +/- 20 foot. A superb pilot won't even let you know the plane changed altitude. Same tolerances in a turn. How steeply should I be able to turn coordinated and without losing altitude? A matter of math, since you have to figure the maximum coefficient of lift necessary to determine the absolute max bank angle the wing is capable of. However, you should try for coordination in ALL turns, regardless of bank. I can do standard turns well enough, but how much steeper do I have to go? Steep turns are those up to 60*. Keep trying. And stop crossposting. TheSmokingGnu |
![]() "Darkwing" theducksmail"AT"yahoo.com wrote BLAH BLAH BLAH. Hope this helps. Thanks. Until you responded and quoted the entire post, I did not see it. Thanks for nothing. -- Jim in NC |
Hey, don't feed him.
The Impossibility of Flying Heavy Aircraft Without Training | george | Piloting | 2 | March 19th 06 08:40 PM |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 01:15 AM |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Home Built | 331 | March 10th 06 01:07 AM |
small partnership questions | TTA Cherokee Driver | Owning | 13 | August 28th 04 04:26 PM |
Looking for official procedures for flying a small aircraft (PC-6 Porter) | My nickname is... | Piloting | 4 | November 11th 03 11:45 PM |
