Attached file should open into Google Earth, if you have it installed.
It's tagged as a cruise missile but the "wings" look a little too short. It's flying in an apparently straight line across Utah, USA. |
Looks like a 737 with dark wings. Exhaust trail behind indicates 2
engines - fuselage mounted. |
On Mon, 5 Mar 2007 13:06:00 -0500, "Jim"
wrote: Looks like a 737 with dark wings. Exhaust trail behind indicates 2 engines - fuselage mounted. Except that the 737 has wing-mounted engines. Maybe it's the FBI's BAU en route to another exciting episode of "Criminal Minds". Have you noticed that wherever they go, there's always a black Chevy Suburban waiting for them? |
![]() "Jim" schrieb im Newsbeitrag ... Looks like a 737 with dark wings. Exhaust trail behind indicates 2 engines - fuselage mounted. The 737 has wing mounted engines. The engines, if the two white spots are engines, are very near to the wing roots. Thus I think it is a Gufstream IV. See attached photo. -- Gruß Matze |
![]() "Matze" wrote in message ... "Jim" schrieb im Newsbeitrag ... Looks like a 737 with dark wings. Exhaust trail behind indicates 2 engines - fuselage mounted. The 737 has wing mounted engines. The engines, if the two white spots are engines, are very near to the wing roots. Thus I think it is a Gufstream IV. See attached photo. Yes, I'm with you. Particularly in view of the fact that the bizjets with fuselage-mounted engines tend to have the wings a long way back. |
Comparing the image to the scale shown on Google Earth it appears that
the wingspan is @75Feet and the fuselage @97Feet. Those are just my best guesses. The edges aren't very well defined on the image. Given those sort of dimensions I don't believe this would qualify as a Cruise Missile. For some comparison Airliners.net provided the following dimensions. Gulfstream IV is @78Foot Wingspan, @88feet in the Fuselage DC9 is listed @90feet, @105Feet Fuselage CRJ900 @82Feet, 120Feet CRJ200 @70Feet, 87Feet Location N38 13 35 W112 17 56 What airways(air highways) are in the area? Looks like it may be heading from Arizona to Salt Lake Utah. My Google Earth says the image was from Digital Globe April 7, 2006. There are several flights between PHX and SLC that use the CRJ series. So my guess would be a regional tripper that just happened to be caught in the act by the passing Sat. So a few more pieces to the puzzle...oh and a little tracking map that shows a route that appears to be through the same area. GMan |
I thing either DC-9 or B-727 with engines mounted on rear fuselage.
Rob "Jim" wrote in message ... Looks like a 737 with dark wings. Exhaust trail behind indicates 2 engines - fuselage mounted. |
NoJags Neil schrieb:
Attached file should open into Google Earth, if you have it installed. It's tagged as a cruise missile but the "wings" look a little too short. It's flying in an apparently straight line across Utah, USA. Its an IVBM Inter Village Ballistic Missile. But the Guys from Circleville missed the airstrip in Juction, inflicting some damage on a forestal road near Delano Peak instead. |
NoJags Neil wrote:
Attached file should open into Google Earth, if you have it installed. It's tagged as a cruise missile but the "wings" look a little too short. It's flying in an apparently straight line across Utah, USA. CJR Looks Like Delta Note the dark nose under, around the cockpit. |
Maple1 wrote:
NoJags Neil wrote: Attached file should open into Google Earth, if you have it installed. It's tagged as a cruise missile but the "wings" look a little too short. It's flying in an apparently straight line across Utah, USA. CJR Looks Like Delta Note the dark nose under, around the cockpit. Aurora stealth transport taking captured terrorists off to "Rendition"? It lands at San Clemente Island, California, ever so often too. Cheers, Dave |
