Bending longeron
Old March 6th 07, 02:24 AM posted to rec.aviation.homebuilt
J.Kahn
Default Bending longeron
Lou wrote:
On Mar 5, 2:29 pm, Jerry Wass wrote:
J.Kahn wrote:
I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube,
with a tight bend radius, no more than 3 inches. Can I do the bend hot
without wrinkling the tube by free bending or do I need a supporting die
of some kind? Anybody have any specific techniques?
John
--I bent some of the same tube by filling it with sand, bending it
around a 10" pulley that had been turned out inside to 3/8"
radius--Pulling it around with the inner race of a big ball brg that had
used 3/4" balls--this was pressed onto a smaller brg which was bolted to
a bar that pivoted on the center support of the pulley. BUT--
that's a 5" radius & you want 3"---might do it though..send ya a pic if
your interested. wass biplane at tds dot net
Can't you use a conduit bender?
Lou
Apparently you can but the radius I need is smaller than a conduit bender.
Old March 6th 07, 02:40 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Use that, then tweak it?
Jim in NC
Bending graphlite rod [email protected] Home Built 15 July 25th 06 06:43 AM
Bending sheet stock Michael Horowitz Restoration 1 April 24th 06 04:28 AM
Wing Bending Oscillation jcarlyle Soaring 18 February 21st 06 04:37 PM
Bending extruded angle Veeduber Home Built 8 August 29th 04 12:58 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
