Morgans wrote:
"J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? Good luck, without a die bender. I have heard of some people bending tube by packing it, very tight, with sand. I have never done it, personally. We're only talking 30 degrees here guys. Sheesh! Mark on either side of your 30 degrees. Heat the inside of the bend in the area between the marks to a dull red, then each of you grab a side and bend it into the hot area as if you were back peddling a canoe. Don't add a lot of pressure. You're just "assisting" the torch heat. Let it cool completely, and do it again if you don't have enough bend. |
Bending graphlite rod | [email protected] | Home Built | 15 | July 25th 06 06:43 AM |
Bending sheet stock | Michael Horowitz | Restoration | 1 | April 24th 06 04:28 AM |
Wing Bending Oscillation | jcarlyle | Soaring | 18 | February 21st 06 04:37 PM |
Bending extruded angle | Veeduber | Home Built | 8 | August 29th 04 12:58 AM |
Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 06:15 PM |
