Taxi speed
Old March 6th 07, 05:49 PM posted to rec.aviation.piloting
Andy Hawkins
Default Taxi speed
Hi,
747 and 777, 15 knots. At least that's what we, as mechanics were taught.
Slowing to 8ish in turns.
Just out of interest, how do you measure speed on the ground? Obviously the
airspeed indicator isn't much use in these situations...
(This is from a sim 'pilot', so might seem like a daft question!)
Andy
Old March 6th 07, 07:38 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Taxi speed
GPS and inertial nav units can provide ground speeds.
Old March 6th 07, 08:06 PM posted to rec.aviation.piloting
Mxsmanic
Default Taxi speed
Andy Hawkins writes:
If you have fancy avionics, they'll tell you your actual ground speed, as read
from an IRU or GPS.
Old March 31st 07, 04:27 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Taxi speed
Mxsmanic wrote in
Obviously the airspeed indicator isn't much use in these
situations...
as read from an IRU or GPS.
Says mr know nothing..
Bertie
Old March 31st 07, 08:19 AM posted to rec.aviation.piloting
Flydive
Default Taxi speed
Bertie the Bunyip wrote:
Mxsmanic wrote in
situations...
Bertie
But he is right
Old March 31st 07, 09:02 AM posted to rec.aviation.piloting
Default Taxi speed
Flydive wrote in :
Mxsmanic wrote in
situations...
speed,
Bertie
But he is right
Not really. We use them as a rough guide but they're not all that
reliable on the ground. Only as a guide. Older widebodies had ground
speedos just like a car. Just a little clock on the capt's panel down
the bottom, usually. All newer ones use IRS, but
IRS info can be out by up to 10 knots by the time you land. A
negligable error in flight, but huge on the ground. Also ****s up your
wind indications on appraoch. Not a problem for a pilot, BTW, but it
does screw up the automatics if they get confused about the crosswind on
some airplanes.
It's not uncommon for them to show movement while you're parked after a
long flight particualrly if radio update isn't all the best towards the
end. Like if you're flying into an area without a lot of DMEs. newer GPS
stuff is better, but it's not really neccesary anyway except in 74's
wher it's quite difficult to tell your GS.
Bertie
Old March 31st 07, 10:12 AM posted to alt.disasters.aviation,rec.aviation.piloting,alt.usenet.kooks
Flydive
Default Taxi speed
Flydive wrote in :
Mxsmanic wrote in
situations...
speed,
Bertie
But he is right
some airplanes.
Bertie
True in part, the latest FMS use the GPS as primary source, so the GS
indication is quite accurate on the ground.
Old March 31st 07, 10:35 AM posted to rec.aviation.piloting
Default Taxi speed
Flydive wrote in :
Flydive wrote in :
Mxsmanic wrote in
situations...
speed,
Bertie
But he is right
your wind indications on appraoch. Not a problem for a pilot, BTW,
but it does screw up the automatics if they get confused about the
crosswind on some airplanes.
after a
the end. Like if you're flying into an area without a lot of DMEs.
newer GPS stuff is better, but it's not really neccesary anyway
except in 74's wher it's quite difficult to tell your GS.
Bertie
If you need it. He was stil worng.
bertie
Old April 8th 07, 09:23 PM posted to rec.aviation.piloting
Not4wood
Default Taxi speed
Hmm, interesting posts.
According to what I've read from the Manuals/Specs most are recommended to
taxi at about 20 and turns are at 12 or slower. I haven't seen that many
manuals or specs, maybe round 3 or 4 but they pretty much had the same taxi
speed requirements. Any faster than that, and I've seen mentioned of tire
and brake wear.
When I was sitting behind the Pilot in a Beaver, he kept it to a slow crawl
at all times. Probably because the taxi way was kinda bumpy and didn't want
us tossed around. Comfort of the paying customers is paramount. How would
you feel sitting in an Airbus and getting your cookies tossed around because
the Pilot was trying to make up some speed on the ground and couldn't care
about your comfort? I don't think so. Remember, the Pilot is responsible
for everyone's safety and their comfort.
http://img.photobucket.com/albums/v4...a/IMG_0290.jpg
Mark G
Not4wood
"Andy Hawkins" wrote in message
Hi,
Andy
Old April 9th 07, 12:35 PM posted to rec.aviation.piloting
Ron Natalie
Default Taxi speed
Something that's going to bounce you to the ceiling in a only going to
be a hiccup in an Airbus.
Taxi accident at OSH StudentPPSEL Owning 4 August 3rd 06 09:52 PM
Hanoi Taxi john smith Piloting 0 April 27th 06 03:48 AM
License To Taxi? SteveT Piloting 29 October 16th 05 04:57 PM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
taxi in reverse? [email protected] Owning 20 February 21st 04 12:26 AM
