I know of one to get out of a decathlon. It was from the back seat no less.
(It helps when the wing has departed and there is a big hole above your head though) Mike john smith wrote: In article . net, "Todd W. Deckard" wrote: Why would you say this? The door would be fairly easy to open in a spin. In a high speed loss of control it might be very difficult to overcome aerodynamic resistance but it is possible to open a forward hinged door and force it open enough to squeeze out at even 100kts in straight flight. With a modern canopy you stand a chance of a survivable deployment at even a few hundred feet. I wouldn't be too positive about those statements. I have over 300 freefalls and 25 hours of acro in a Citabria. The Citabria only has one door... on the right side. In a right spin, the rate of descent is still going to be about 800 fpm with an indicated airspeed of 45-50 mph. That's quite and airload on the inside turn side of the airframe. Add to that centrifugal forces and getting through the doorway after jettisoning the door will be a challenging proposition. You have two sets of seatbelts to release, a headset to remove and a body with a parachute attached to fit through the doorway. When you exit you will be on the inside side of the airplane, which you have to clear before you pull the D-ring. Tic-toc, the clock is winding down as fast as the altimeter. I have knowledge of only one acro pilot who successfully exited a Decathlon. |
Rolling a Non Aerobat 150 | Larry Dighera | Piloting | 98 | June 18th 05 12:28 AM |
Rolling a Non Aerobat 150 | Jose | Instrument Flight Rules | 1 | May 2nd 05 03:59 PM |
Rolling a Non Aerobat 150 | Jose | Piloting | 1 | May 2nd 05 03:59 PM |
Rolling a Non Aerobat 150 | Larry Dighera | Piloting | 1 | April 29th 05 07:31 PM |
Rolling a Non Aerobat 150 | kage | Owning | 0 | April 29th 05 04:26 AM |
