![]() "Robert Scott" ---@--- wrote in message ... On 6 Mar 2007 06:23:10 -0800, " wrote: On Mar 6, 6:16 am, ---@--- (Robert Scott) wrote: On 5 Mar 2007 06:41:42 -0800, " wrote: The only way to get perfect results is for the wind to be calm. A 10 MPH breeze give you false readings, At least it does on the Acers unit.. YMMV... Are you saying that a 10 MPH breeze causes a perfectly balanced prop to vibrate noticeably? Robert Scott Ypsilanti, Michigan Nope... What happens is the wind gusts during the actual balancing operation will affect the unit from stabilizing and giving you a good location and amount of weight to add... How long does it normally take, running at full RPM, to get a stable reading on one of these balancer systems? Robert Scott Ypsilanti, Michigan The machine tells you when it is getting a good reading (usually after about 30 seconds or so at power depending on conditions) then you hit the record button and and 3-4 seconds later you have your reading. I am not sure if we are talking about the same machine, ours is an Aces. Allen |
On Mar 7, 5:54 am, "Allen" wrote:
"Robert Scott" ---@--- wrote in message ... On 6 Mar 2007 06:23:10 -0800, " wrote: On Mar 6, 6:16 am, ---@--- (Robert Scott) wrote: On 5 Mar 2007 06:41:42 -0800, " wrote: The only way to get perfect results is for the wind to be calm. A 10 MPH breeze give you false readings, At least it does on the Acers unit.. YMMV... Are you saying that a 10 MPH breeze causes a perfectly balanced prop to vibrate noticeably? Robert Scott Ypsilanti, Michigan Nope... What happens is the wind gusts during the actual balancing operation will affect the unit from stabilizing and giving you a good location and amount of weight to add... How long does it normally take, running at full RPM, to get a stable reading on one of these balancer systems? Robert Scott Ypsilanti, Michigan The machine tells you when it is getting a good reading (usually after about 30 seconds or so at power depending on conditions) then you hit the record button and and 3-4 seconds later you have your reading. I am not sure if we are talking about the same machine, ours is an Aces. Allen- Hide quoted text - - Show quoted text - It's the same machine and the same time to aquire the info... |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
dynamic prop balancing | George A. Graham | Home Built | 2 | April 21st 05 01:20 PM |
Dynamic prop balance | Ben Jackson | Owning | 18 | June 27th 04 01:45 AM |
Need Micro Balancer | Jim | Products | 39 | August 26th 03 01:34 AM |
Need Micro Balancer | Jim | Rotorcraft | 35 | August 26th 03 01:34 AM |
