![]() wrote in message oups.com... On Mar 6, 4:38 pm, "Bill Daniels" bildan@comcast-dot-net wrote: "Tuno" wrote in message oups.com... This topic is most interesting. I was never taught the low tow, or presented with the concept at any of the 3 places I took lessons (Estrella, Seminole Lakes and Turf, 3 years ago). How is it easier for the glider driver? Wouldn't it create more work for the tug driver? Are there any enthusiasts of the low tow who are also enthusiasts of high wing loading for those good days? I've been in the "low tow" position unintentionally at max wing loading when the tug driver musta thought he was pulling a 2-33. Seems like there would be no room for error if one started out in that position, and the tug then slowed down! ~ted/2NO I probably flew hundreds of low tows at the old El Mirage Field. Gus Brigleib insisted on low tow. If you are flying a low performance glider, the technique for slack is to just push the nose lower. The glider will just move down and take the slack out. If, however, you are flying a Nimbus, it will outrun the tug pasing under it. Pulling up puts in more slack even as the glider slows down ending in a jerk. In the end, I suspect the reason Gus insisted on low tow was the TG-3's he used as trainers. It was very difficult for the instructor, sitting 8 feet or so behind the student, to see the tug while in high tow. There was a lot of rollover structure and greenhouse canopy between the front and rear cockpits. Low tow gives the instructor a great view of the tug. I really can't think of another reason for low tow. BTW, low tow seems easier only because there are fewer references, like the horizon, to help detect being out of position. If you can't tell you are out of position, it seems OK. In fact, the opposite may be true. In high tow, the tugs wingtip vortices tend to push a glider back to center position. In low tow, they tend to pull it out of position. Bill Daniels Gotta jump on this one- sorry Bill! Suggestion of moving down to take up slack is absolutely wrong. This will increase relative speed of glider and make the situation worse. The usual reason for slack is glider quickly descending and thus slightly overtaking tug. Just like what creates slack in high tow. Proper technique when you get some slack is simply slide out to the side until slack comes out. Then return to proper vertical position and move back to center. Since you are below the wake , vortices are not really and issue. One of the nice parts about low tow is that you feel the wake on the vertical tail as height warning instead of fuselage descending into wake and causing glider to want to start out of position. 2-33 drivers will recognize this scenario. BTW- we've tried top stall the tug by pulling the tail down and not been able to do it. Cheers UH Please note that I did qualify my statement with the phrase "low performance glider". In the days I was flying low tow, it was rare to find a glider with more than 30:1. The 2-22's were about 20:1. These glilders won't accelerate as you nose down. As you point out, higher performance gliders will over run the rope. Wing tip vortices have a laminar far field effects that extends at least one tug wingspan. I did some wing tip vortex turbulence studies in the 1960's with smoke grenades on the tug wing. That was one of the results. It means that the glider is always under the influence of the two wingtip vortices coming from the tug whether the pilot can sense the turbulence or not. An interesting experiment is to position the glider to one side while in high tow. Then, keep the gliders wings exactly level with reference to the tug but otherwise allow the glider to go where it will. The glider will gently swing back to center as it is pushed by the wing tip vortex. Try that in low tow and the vortex flow will pull the glider away from center. Bill Daniels |
And you thought AMARC was bad.... | Ron | Aviation Photos | 18 | February 2nd 07 05:27 AM |
Thought Police | Michael Baldwin, Bruce | Products | 0 | November 17th 06 06:58 AM |
Just when I thought I'd heard it all:-) | Dudley Henriques | Piloting | 14 | November 23rd 05 08:18 PM |
A thought on BRS | Martin Gregorie | Soaring | 47 | April 29th 04 06:34 AM |
I thought some of these are classics | goneill | Soaring | 0 | April 8th 04 10:51 AM |
