If you look at the mid section of the aircraft, you can see two dark, swept
wings continuing out from the "stubs". From the distance of the photo, the dark color doesn't seem to stand out from the background like the white painted fuselage. Rob "Jim" wrote in message ... The picture was taken from a Satelite at an alt of around 350 miles I would guess. It is obvious that there are fins aft and stubs at the mid body. I doubt that we are seeing a contrail, I think we are seeing exhaust from one or two rocket motors. The stubs at the mid body could be un deployed wings. IMHO it is either a cruise missile after launch, but prior to air start of the air breathing engine, in other words prior to burn out of the first stage solid rocket motor. Or it is a lifting body type aircraft like the old X15. I think the former is more likely than the latter. On Mon, 5 Mar 2007 16:15:03 -0000, "NoJags Neil" wrote: Attached file should open into Google Earth, if you have it installed. It's tagged as a cruise missile but the "wings" look a little too short. It's flying in an apparently straight line across Utah, USA. -- Jim in Houston osPAm Nurse's creed: Fill what's empty, empty what's full, and scratch where it itches!! RN does NOT mean Real Nerd! |
