On Mar 9, 12:24 pm, Michelle P
wrote: wrote: On Mar 8, 6:56 am, Michelle P wrote: TheSmokingGnu wrote: Here's one that may seem silly: to what height, precisely, is an altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). What is the answer, o Swammi of Salami? TheSmokingGnu When doing the bi-annual? the calbration is at the height of static port. Michelle But a static port at a lower level won't result in a higher static pressure at the altimeter. There's a pressure drop with altitude inside the line, too, just as there is in a water-filled tube. I would imagine the pilot of a machine with its altimeter 20 feet off the ground would note a 20-foot discrepancy with the field elevation once the altimeter has been set to the controller's numbers. Dan that is why they allow a 75ft deviation. Michelle Thats what we need deviant altimeters :-) |
They go with deviant pilots, no? Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
Deck height | Sean Trost | Home Built | 5 | July 16th 04 03:46 AM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
