Do you have to solo to get current?
Old March 9th 07, 06:57 AM posted to rec.aviation.piloting
Maxwell
Default Do you have to solo to get current?
"BT" wrote in message
but the other pilot is not current either... so neither of you can be PIC
Neither of you can be PIC to carry a *passenger*, but 61.57 doesn't say you
can't carry another *pilot*.
and you are in a "single pilot airplane", so there is only one pilot
required and the other is a passenger
The regs do not specify that you can't have two pilots *present* in a
aircraft that doesn't require them, just that they can't both log the time.
Old March 9th 07, 10:19 PM posted to rec.aviation.piloting
Blueskies
"Maxwell" wrote in message ...
: "BT" wrote in message
: but the other pilot is not current either... so neither of you can be PIC
: Neither of you can be PIC to carry a *passenger*, but 61.57 doesn't say you
: can't carry another *pilot*.
: and you are in a "single pilot airplane", so there is only one pilot
: required and the other is a passenger
: The regs do not specify that you can't have two pilots *present* in a
: aircraft that doesn't require them, just that they can't both log the time.
Pilot is a subset of passenger. All persons in the aircraft are passengers, and some passengers are also pilots....
Old March 9th 07, 10:42 PM posted to rec.aviation.piloting
Judah
"Blueskies" wrote in
Are you sure? If that's the case, how can the pilot himself fly?
First Solo W P Dixon Piloting 8 August 16th 06 05:07 AM
How do you keep current? Rachel Piloting 18 January 30th 06 01:24 AM
L33 Solo Jeff Runciman Soaring 1 November 14th 05 08:57 AM
1.4 solo.. Beav Rotorcraft 0 November 5th 04 12:27 AM
Solo in a 2-32 M B Soaring 3 September 30th 03 03:11 AM
