Shortened McCauley Propeller on an O-300
Old September 9th 03, 05:21 PM
Larry Smith
Thanks, Cy, for your usual splendid courtesy. I found the tcds for the AIQ and it permits a prop of diameter no less than 75.5" so I don't think this prop is legal for it.
"Cy Galley" wrote in message news:jPl7b.406837$uu5.73583@sccrnsc04...
If it was on a Cessna 170, then ...
Propeller
(a)
McCauley 1A170
33 lb.
(-39)
(-39)
(-39)
Static r.p.m. at max. permissible throttle setting:
Landplane: Not over 2330, not under 2230
Seaplane (Models 170A and 170B): Not over 2525, not under 2300.
No additional tolerance permitted.
Diameter: Not over 76 in., not under 74.5 in.
Propeller spinner, dwg. No. 0550101-3
-eligible-
Propeller spinner, dwg. No. 0550162
2 lb.
(-39)
(-39)
(-39)
So you current length should be O.K. The problem of prop shortening I believe was when they chopped several inches below the minimum approved length.
"Larry Smith" wrote in message ...
A year or so ago there was a thread about shortened aluminum prop blades,
especially on Sensenich props, going into flutter and departing O-320's.
And I recall that Rich Shankland decided not to use the bargain prop he had
bought for his Emeraude.
Now here's an aluminum McCauley which was originally 76" and is now 75.188.
In other words 13/32" have been removed from each blade, reducing its
diameter by 13/16".
It seems ac 43.13A, McCauley, or the tcds ought to say something about this
and the limits a prop may be shortened but I haven't found it yet. Anybody
know if this prop would be legal on a certified aircraft with a Continental
O-300? Or can direct us to the pertinent specs?
Thanks.
Old September 9th 03, 05:46 PM
Cy Galley
Propeller and propeller
limits from the 172 TCDS
1.
Propeller
(a)
McCauley 1A170
Static rpm at maximum permissible throttle setting:
Not over 2360, not under 2230
Diameter: not over 76 in., not under 74.5 in.
Propeller
(a)
McCauley 1A170
33 lb.
(-39)
(-39)
(-39)
-eligible-
2 lb.
(-39)
(-39)
(-39)
diameter by 13/16".
Thanks.
MT MTV-9-B-C/C190 Propeller for Sale - Pitts N5351N.jpg (0/1) Chris Nehls Aerobatics 2 December 19th 04 05:38 AM
propeller calculation and how to build jgarner Home Built 7 August 25th 03 03:23 AM
Propeller Jan Carlsson Home Built 11 July 12th 03 10:36 PM
