In article nk.net,
Dave S wrote: I dont know about the approach itself, but the power issue is very believable. If the main transformer for the whole place let go, its VERY likely that it takes 10 or more seconds for the generator to get up and running. Also, if I understand right, the generators dont serve the entire airport, just select facilities and one or two main runways. An approach system doesn't have a UPS? -- Bob Noel (gave up lookingn for a particular sig the lawyer will) |
![]() "Bob Noel" wrote in message ... In article nk.net, Dave S wrote: I dont know about the approach itself, but the power issue is very believable. If the main transformer for the whole place let go, its VERY likely that it takes 10 or more seconds for the generator to get up and running. Also, if I understand right, the generators dont serve the entire airport, just select facilities and one or two main runways. An approach system doesn't have a UPS? The article said it took a few seconds to kick in. |
The article said it took a few seconds to kick in. UPS's don't need time to "Kick In" That is why thet are called UnInteruptable Power Supplies. Generator power is another story. Typicall transfer times are generally in the neighborhood of 10 seconds from a cold start to power transfer. Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
Mike 'Flyin'8' wrote: UPS's don't need time to "Kick In" That is why thet are called UnInteruptable Power Supplies. UPS are usually designed to come online within a couple of cycles. |
Mike 'Flyin'8' wrote: UPS's don't need time to "Kick In" That is why thet are called UnInteruptable Power Supplies. UPS are usually designed to come online within a couple of cycles. I have never seen a UPS that takes more than a fraction of a cycle to transition to backup mode. In fact, units which are used in "mission critical" applications are not the line interactive type as you seem to be thinking about above, instead are dual online conversion. I would assume that a UPS used for ILS equipment and radio communications for ATC would be a mission critical design as opposed to the less than reliable line interactive design. The dual online conversion types are actually running off battery and an oscillator all the time. There is no switching time. But hey... What do I know... Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
On Fri, 09 Mar 2007 17:48:01 -0800, Mike 'Flyin'8'
wrote: In article , Mike 'Flyin'8' wrote: UPS's don't need time to "Kick In" That is why thet are called UnInteruptable Power Supplies. UPS are usually designed to come online within a couple of cycles. I have never seen a UPS that takes more than a fraction of a cycle to transition to backup mode. In fact, units which are used in "mission critical" applications are not the line interactive type as you seem to be thinking about above, instead are dual online conversion. I would assume that a UPS used for ILS equipment and radio communications for ATC would be a mission critical design as opposed to the less than reliable line interactive design. The dual online conversion types are actually running off battery and an oscillator all the time. There is no switching time. But hey... What do I know... There are also "bridge" UPSes that store energy in flywheels and ultracapacitors. Don |
![]() There are also "bridge" UPSes that store energy in flywheels and ultracapacitors. I'm no UPS or Power engineer, but isn't the flywheel bridge used to "bridge" the time it takes for a generator to come online. I was not aware that there are UPS's using this technology. While ultracaps do store energy, they are typically only sized to maintain an output load for a period of about 30 seconds in the flywheel bridge. This application isn't really a UPS per se, though would be awesome to prevent the failure Capt Doug speaks of. My specialty isn't UPS's, rather telecom, so take it all with a grain of salt. Reading Capt Dougs story makes one wonder about the reliability of the "things" we rely on for our navigation, communications etc while flying around. I am a new pilot and would be kinda bummed out if on final at night and the runway lights went out. Though I probably shouldn't be, I think I am dependent upon the runway edge lighting to make a landing at night... Maybe I am wrong... but dang that would be an eye opener for sure if those things went out on me while on short final, or even worse, just seconds before touchdown. Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
![]() Mike 'Flyin'8' wrote: UPS are usually designed to come online within a couple of cycles. I have never seen a UPS that takes more than a fraction of a cycle to transition to backup mode. We have UPS's in the tower and TRACON. They work only when properly maintained. Ours are not and it's a 50/50 bet that the entire tower/TRACON will reset when they don't work. If they don't work it's a 10-15 second deal while everything comes back on line. That's why we always manually turn on the back up generators whenever there are thunderstorms in the area. In fact, units which are used in "mission critical" applications are not the line interactive type as you seem to be thinking about above, instead are dual online conversion. I would assume that a UPS used for ILS equipment and radio communications for ATC would be a mission critical design as opposed to the less than reliable line interactive design. They are not. |
Newps wrote:
Mike 'Flyin'8' wrote: UPS are usually designed to come online within a couple of cycles. I have never seen a UPS that takes more than a fraction of a cycle to transition to backup mode. We have UPS's in the tower and TRACON. They work only when properly maintained. Ours are not and it's a 50/50 bet that the entire tower/TRACON will reset when they don't work. If they don't work it's a 10-15 second deal while everything comes back on line. That's why we always manually turn on the back up generators whenever there are thunderstorms in the area. In fact, units which are used in "mission critical" applications are not the line interactive type as you seem to be thinking about above, instead are dual online conversion. I would assume that a UPS used for ILS equipment and radio communications for ATC would be a mission critical design as opposed to the less than reliable line interactive design. They are not. If you keep posting facts instead of idle speculation you're going to ruin USENET. |
![]() "Mike 'Flyin'8'" wrote in message ... An approach system doesn't have a UPS? The article said it took a few seconds to kick in. UPS's don't need time to "Kick In" That is why thet are called UnInteruptable Power Supplies. Generator power is another story. Typicall transfer times are generally in the neighborhood of 10 seconds from a cold start to power transfer. So..was it really a UPS, or a backup generator? Remember, the story we got was 2nd hand/anecdote. |
Upcoming Soaring Events in Pennsylvania | [email protected] | Soaring | 3 | February 11th 07 06:18 AM |
NNUSAF Upcoming Events | john smith | Piloting | 0 | January 5th 07 09:41 PM |
Aviation Events Calendar(s) -- Which One(s)? | Jay Honeck | Piloting | 4 | October 8th 05 12:39 AM |
Friendly fire pilot blames poor chain of command | Otis Willie | Military Aviation | 0 | July 6th 04 10:47 PM |
Oshkosh non flying female spousal events? | Ken Finney | Home Built | 5 | April 3rd 04 10:52 PM |
