TPAS and Transponder - Blind Spot
Old March 10th 07, 05:36 PM posted to rec.aviation.soaring
jcarlyle
Default TPAS and Transponder - Blind Spot
Eric, sorry about the typo in your name in the message above.
Figuring out the geometry is involved, but some signal overlap is OK.
Explaining it in text is hard, but if you make timing diagrams on a
sheet of paper and translate that to geometry, you'll see the
solution. I think that if someone is in your ATC blind zone, and a
TPAS interrogates your transponder and his, and he's outside of the
TPAS blind zone, you'll see him.
Glad you'll try to call Zaon; this coming week is one I want to forget
before it even gets here!
-John
On Mar 10, 11:29 am, Eric Greenwell wrote:
As long as they don't overlap, then maybe the unit can still pick out a
potential threat.
Sure, I'll try to contact them Monday.
Old March 10th 07, 05:53 PM posted to rec.aviation.soaring
ZL
-John
potential threat.
Don't forget, there is a finite delay in the transponder (3.0
microseconds by spec) between receiving the pulse from ATC and replying.
You're not looking for echoes here.
-Dave
Old March 10th 07, 06:00 PM posted to rec.aviation.soaring
ZL
-John
potential threat.
-Dave
never mind, doesn't matter...
Monroy ADT-200 TPAS Ramy Yanetz Soaring 6 May 10th 05 09:58 AM
TPAS experiences - good, bad, and ugly Eric Greenwell Soaring 1 January 19th 05 09:49 PM
Blind 430 john smith Owning 16 January 4th 05 07:57 PM
FS : TPAS Sure Check model RX-110 Brian Aviation Marketplace 0 September 16th 04 03:21 PM
Surecheck TPAS (was Proxalert R?) Tim Mara Soaring 0 February 10th 04 07:19 PM
