fixed wing or rotary wing?
Old March 10th 07, 07:54 PM posted to rec.aviation.rotorcraft
Don W
Default fixed wing or rotary wing?
Craig Campbell wrote:
I never really thought much about doing fixed wing, would that be worth
doing just to have or really only if I really wanted to use it?
"601XL Builder" wrDOTgiacona@suddenlinkDOTnet wrote in message
I am about to start my private pilot helicopter course. I have been told
that learning fixed wing first makes it much easier.
I am not sure what to do as my heart was set on rotary but I want to do
it right first time.
Can anyone please give me feedback on this?
Thanks
Craig Campbell
If you plan on getting both get the fixed wing first. It will be cheaper.
If you don't plan on flying fixed wing, I'm not
sure it would be cheaper to get the fixed wing
license first. It's true that you can learn to
fly, navigate, and work the radios in $75/hr
airplanes instead of $200-$250/hr helicopters, but
you will still have to do the transition to
rotorcraft for your helicopter license.
The way I read Part 61.109 (copied below), the
minimum number hours you would have to have in a
helicopter for the transition would be:
3 hours (Combined Dual Night/Cross country)
2 hours (10 Dual takeoffs and landings to stop)
3 hours (Dual training prep for check ride)
10 hours (solo)
18 hours helicopter minimum
If you could learn everything you needed to learn
on the helicopter in that time, it would be
incredible. A more likely transition scenario
would be something like 30 hours.
So in that case, you would save ten or so hours of
helicopter time, by spending 40 hours of fixed
wing time.
Doing the math with the following assumptions:
Fixed Wing = C150 @ $75/hr wet
Fixed Wing Instructor = $30/hr
Helicopter = R22 @ $225/hr wet
Heli Instructor = $30/hr
Heli Transition = 15 Dual, 10 Solo
Fixed wing plus Rotary route:
Fixed Wing (20*$105)+(20*$75)
Helicopter (15*$255)+(10*$225)
Total = $9,675 + Ground Instruction
and you would have a Fixed and Rotary Wing Rating
Heli only route:
Helicopter (20*$255)+(20*225)
Total = $9600 + Ground Instruction
and you would have Rotary Wing only rating
So it would probably be slightly more expensive to
start in fixed wing and transition to helicopter.
As far as the easy part, I found it relatively
easy to transition from fixed wing to the R22.
Regards,
Don W.
Part 61.109 (c)
c) For a helicopter rating. Except as provided in
paragraph (k) of this section, a person who
applies for a private pilot certificate with
rotorcraft category and helicopter class rating
must log at least 40 hours of flight time that
includes at least 20 hours of flight training from
an authorized instructor and 10 hours of solo
flight training in the areas of operation listed
in §61.107(b)(3) of this part, and the training
must include at least—
(1) 3 hours of cross-country flight training in a
helicopter;
(2) Except as provided in §61.110 of this part, 3
hours of night flight training in a helicopter
that includes—
(i) One cross-country flight of over 50 nautical
miles total distance; and
(ii) 10 takeoffs and 10 landings to a full stop
(with each landing involving a flight in the
traffic pattern) at an airport.
(3) 3 hours of flight training in preparation for
the practical test in a helicopter, which must
have been performed within 60 days preceding the
date of the test; and
(4) 10 hours of solo flight time in a helicopter,
consisting of at least—
(i) 3 hours cross-country time;
(ii) One solo cross-country flight of at least 75
nautical miles total distance, with landings at a
minimum of three points, and one segment of the
flight being a straight-line distance of at least
25 nautical miles between the takeoff and landing
locations; and
(iii) Three takeoffs and three landings to a full
stop (with each landing involving a flight in the
traffic pattern) at an airport with an operating
control tower.
Old March 10th 07, 08:48 PM posted to rec.aviation.rotorcraft
Craig Campbell
Thanks for the break down of $'s Don. Okay so I suppose my next question
is.... Would it be of any benefit to me trying to get a helicopter pilot
job having also become rated in fixed wing? Am I a more attractive
applicant? Or are the two mutually exclusive?
Craig Campbell
"Don W" wrote in message
t...
told that learning fixed wing first makes it much easier.
Thanks
Craig Campbell
If you don't plan on flying fixed wing, I'm not sure it would be cheaper
to get the fixed wing license first. It's true that you can learn to fly,
navigate, and work the radios in $75/hr airplanes instead of $200-$250/hr
helicopters, but you will still have to do the transition to rotorcraft
The way I read Part 61.109 (copied below), the minimum number hours you
would have to have in a helicopter for the transition would be:
10 hours (solo)
If you could learn everything you needed to learn on the helicopter in
that time, it would be incredible. A more likely transition scenario
So in that case, you would save ten or so hours of helicopter time, by
spending 40 hours of fixed wing time.
Heli only route:
So it would probably be slightly more expensive to start in fixed wing and
As far as the easy part, I found it relatively easy to transition from
Regards,
Don W.
Part 61.109 (c)
c) For a helicopter rating. Except as provided in paragraph (k) of this
section, a person who applies for a private pilot certificate with
rotorcraft category and helicopter class rating must log at least 40 hours
of flight time that includes at least 20 hours of flight training from an
authorized instructor and 10 hours of solo flight training in the areas of
operation listed in §61.107(b)(3) of this part, and the training must
include at least—
(1) 3 hours of cross-country flight training in a helicopter;
(2) Except as provided in §61.110 of this part, 3 hours of night flight
training in a helicopter that includes—
(i) One cross-country flight of over 50 nautical miles total distance; and
(ii) 10 takeoffs and 10 landings to a full stop (with each landing
involving a flight in the traffic pattern) at an airport.
(3) 3 hours of flight training in preparation for the practical test in a
helicopter, which must have been performed within 60 days preceding the
(4) 10 hours of solo flight time in a helicopter, consisting of at least—
(ii) One solo cross-country flight of at least 75 nautical miles total
distance, with landings at a minimum of three points, and one segment of
the flight being a straight-line distance of at least 25 nautical miles
between the takeoff and landing locations; and
(iii) Three takeoffs and three landings to a full stop (with each landing
involving a flight in the traffic pattern) at an airport with an operating
control tower.
Old March 10th 07, 09:53 PM posted to rec.aviation.rotorcraft
Steve L.[_3_]
Pretty much the latter. And if you go back to the costs, then there is
no doubt that exclusively helicopter time will be "cheaper".
To get a helo job, you need helo hours. That's what insurance asks for -
usually nobody is interested in your fixed wing hours.
Of course you could get your helicopter commercial with only 50 hours in
helicopters and the remaining 100 in something else. But first you
probably won't be good enough to pass the checkride and second you need
200 hours in helicopters anyway to get your first job which is going to
be instructing. Maybe even 300 hours (common insurance requirement).
So, if you are not interested in fixed wing, go with helicopter hours
wherever possible. Don't even use flight simulators - you need the real
hours. Save your money for the real hours, don't waste it for simulator,
fixed wing... IF you are serious about it. But try fixed wing also
(intro flight)!
Helicopter vs. fixed-wing for leisure Mxsmanic Piloting 16 January 30th 07 11:36 PM
Trikes vs Fixed Wing U/L vs Gyros BARTFIO Rotorcraft 2 September 4th 04 06:29 AM
