What do you do in the real world?
Old March 11th 07, 07:41 AM posted to rec.aviation.ifr
Ron Garret
Default What do you do in the real world?
Newps wrote:
A Guy Called Tyketto wrote:
If it was a vector, that changes the whole story.
That is the story, the original basis for the question...what do you do
if while on a vector you go Nordo.
Actually, it wasn't a vector, it was an off-airway direct clearance.
Similar to a vector in some respects, but not the same thing.
rg
Old March 11th 07, 09:50 AM posted to rec.aviation.ifr
Roger[_4_]
On Sat, 10 Mar 2007 23:41:34 -0800, Ron Garret
It's still a clearance. You fly as cleared be it direct, vector, or
airway. Think of it this way. You have told they what your plan on
doing (fligth plan) If they amend it then you fly the amended
clearance be it a segment or one that takes you to your destination.
So if you were them they expect you to be where you told them you
would be when you told them you would be unless they have changed part
or all of it. So even without radio you are supposed to be where they
expect you to be. UNLESS you encounter VFR conditions. Then you are
expected to head for a nearby airport, and call. If the transponder is
still working follow lost com procedure.
rg
www.rogerhalstead.com
Real-world IFR currency Paul Folbrecht Instrument Flight Rules 47 March 23rd 05 04:19 PM
Real World Problem in FS9 The Real Cali Kid Simulators 12 December 6th 03 11:15 AM
Real World Weather (Isabelle) [email protected] Simulators 1 September 21st 03 09:53 PM
Real-time real world air traffic in flight sims Marty Ross Simulators 6 September 1st 03 04:13 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
