On 03/11/07 11:41, Ron Garret wrote:
[ snip ] First, the regs explicitly sanction "making up your own stuff" (as you put it) in emergency situations, which lost comm in IMC can easily give rise to. Well, *anything* can lead to an emergency situation. However, there are regulations written specifically for the case of lost communications. If you deem that lost communications is an emergency, and use that to justify doing whatever you want, you're in violation of the regs. Second, a lot of the regs were written before the advent of moving-map GPS. Many procedures that make sense if you're navigating on a VOR make less sense if you always know at a glance exactly where you are. Third, going by the book makes you do some overtly stupid things. The classic example is going NORDO while flying from AVX to FUL. Going by the book requires you to fly to SLI, reverse course, return to the exact spot you just came from (which is over water BTW), and reverse course again. I haven't looked at this particular approach, but I'll assume you're referring to the fact that your clearance limit is the airport, and that the regs require you to go to the clearance limit first? First of all, this is what the regulations tell you to do, and this is what you must do. Period. The fact that some controllers tell you that they would rather you do something different is irrelevant. They will not be defending you in a certificate action case. Incidentally, when I file an IFR flight plan, I select a fix which I can use to initiate my approach, and put a note in the remarks section which states: "In the event of lost communications, XYZ shall be treated as my clearance limit." This way, I don't have to do the back and forth - and it's legal (and expected by ATC). This procedure is manifestly more dangerous than just flying the approach straight in (because it involves more maneuvering, more time in the air, more time over water). Moreover, under normal conditions the approach is ALWAYS flown straight in (via vectors) and under NORDO conditions the controllers expect you to fly the approach straight in (I know because I asked them) notwithstanding that this technically violates the regs. And fourth, the regs leave a lot of stuff unspecified. If you go by the regs in the current situation, you end up over KVNY at 11,000 feet, at which point you're supposed to initiate your descent. But there's no published hold at KVNY (to say nothing of the fact that KVNY is not an IAF for any approach to KVNY) so you have no choice but to improvise at that point. Not really. According to the regs, you go to your clearance limit, then to a point where you can begin your approach. Once you're on a published leg of the approach, you fly it's altitudes. This means you can begin your descent once you're on the IAP. If you need to hold at the fix to lose altitude, you do that. rg -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote: I haven't looked at this particular approach, but I'll assume you're referring to the fact that your clearance limit is the airport, and that the regs require you to go to the clearance limit first? Correct. First of all, this is what the regulations tell you to do, and this is what you must do. Period. I'm not asking what is the required course of action. I am asking what is the wisest course of action. The fact that some controllers tell you that they would rather you do something different is irrelevant. They will not be defending you in a certificate action case. Quite so, but keeping my ticket is not my only consideration. There is also the safety of the flight to consider. Following the regs requires more time in the air, more maneuvering, more fuel consumption, and unnecessary traversal of extremely crowded airspace in IMC. All this entails additional risk. If I'm faced with a choice of risking my ticket or risking my safety I'll take the former. Incidentally, when I file an IFR flight plan, I select a fix which I can use to initiate my approach, and put a note in the remarks section which states: "In the event of lost communications, XYZ shall be treated as my clearance limit." This way, I don't have to do the back and forth - and it's legal (and expected by ATC). That seems like a sensible idea. I think I'll try that. This procedure is manifestly more dangerous than just flying the approach straight in (because it involves more maneuvering, more time in the air, more time over water). Moreover, under normal conditions the approach is ALWAYS flown straight in (via vectors) and under NORDO conditions the controllers expect you to fly the approach straight in (I know because I asked them) notwithstanding that this technically violates the regs. And fourth, the regs leave a lot of stuff unspecified. If you go by the regs in the current situation, you end up over KVNY at 11,000 feet, at which point you're supposed to initiate your descent. But there's no published hold at KVNY (to say nothing of the fact that KVNY is not an IAF for any approach to KVNY) so you have no choice but to improvise at that point. Not really. According to the regs, you go to your clearance limit, then to a point where you can begin your approach. Once you're on a published leg of the approach, you fly it's altitudes. This means you can begin your descent once you're on the IAP. If you need to hold at the fix to lose altitude, you do that. And what if there is no published hold (as is the case in the current situation)? rg |
Ron Garret writes:
Quite so, but keeping my ticket is not my only consideration. There is also the safety of the flight to consider. Following the regs requires more time in the air, more maneuvering, more fuel consumption, and unnecessary traversal of extremely crowded airspace in IMC. All this entails additional risk. If I'm faced with a choice of risking my ticket or risking my safety I'll take the former. If you declare an emergency, there is no regulatory problem with this. You don't put your license at risk simply because you do something that you deem essential for the safety of your flight. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mark Hansen writes:
If you deem that lost communications is an emergency, and use that to justify doing whatever you want, you're in violation of the regs. You're never in violation of regulations if you deem a situation to be an emergency. As the pilot in command, your decision on whether or not a situation is an emergency is final (FAR 91.3). Two-way communication by radio is required in controlled airspaces because it is dangerous to have aircraft flying around in them without it. Therefore a loss of radio communication is a potentially dangerous situation, and a pilot may well condider it an emergency. The AIM makes this clear (6-4-1(b)). The determination is made by the pilot alone. Pilots with emergencies are still expected to adhere to the standard IFR lost-communications procedures to the extent possible given the nature of their emergencies. The AIM goes into more detail than the regulations from which it is derived, but it still does not cover every situation, and explicitly says so. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 04:19 PM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 09:53 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
