Mxsmanic wrote:
Tim writes: How is this an emergency? It endangers the flight and other flights around it. Losing all communication in crowded, controlled airspace is clearly an emergency. Bull****. The radio has no bearing on the safety of flight. The flight controls all work fine. That is why you file an ifr flight plan. You state on it your airspeed. If not under radar, you make position reports. If under radar no need to. This is why the regulations (you already quoted) require different procedures in VFR. If you already know the answer and were given instructions by controllers to do this in the past, why pose it here? If you already know the answer, why have you still not provided it? Many other have also discussed it and you already posted the relevant FAR section. The OP claims he got instructions from the local controllers. So, if that is the case, he should just follow those instructions. (Or perhaps they are not regulatory) While your specific example may work for you in this case, applying that logic in other places will get you killed. If you follow the regs the way they are written you will be fine and you won't get in trouble. So what's the answer? See the FARs you already posted. If you have an emergency (and I don;t think a non-op comms radio qualifies) then you certainly can do whatever you need to do to make a safe ending to the flight. Why doesn't an inoperative radio qualify? You're in airspace that requires two-way radio communication. If you are saying that an inop radio is an emergency then I would question your judgment as a pilot. If the pilot thinks it is an emergency, then by all means, "declare" one and treat it as such. Are you saying that piper cubs are always flying around in states of emergency? (they have no electrical system and no radios) - unless modified to have them. So you are saying you don't know what you are supposed to do when you reach a clearance limit and there is no published hold? So enlighten everyone by explaining exactly what he should do. I thought the regs were clear. Others have also offered it up here. |
![]() Tim wrote: If you are saying that an inop radio is an emergency then I would question your judgment as a pilot. If the pilot thinks it is an emergency, then by all means, "declare" one and treat it as such. He's not a farkin pilot, he's not even close. |
Tim,
If you are saying that an inop radio is an emergency then I would question your judgment as a pilot. If the pilot thinks it is an emergency, then by all means, "declare" one and treat it as such. And if it were an emergency, why are there different transponder codes for emergency and lost comm. -- Thomas Borchert (EDDH) |
Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 04:19 PM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 09:53 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
