Dave Anderer writes:
I'm looking for advice to help shorten the trouble-shooting process here. My Arrow has developed an alternator whine over the past few hours. It is *barely, barely" noticable on both radios when receiving, but loud and obnoxious (both to me and other aircraft) when transmitting. No doubt it is the alternator - switching the alternator off fixes the problem. So your first troubleshooting fork is this: 1) The alternator/charging system may be making more ripple than before. or 2) The ripple may be the same, but the comm system is doing a better job hearing it. For 1) two major suspects: a) Bad grounds. b) Bad diode{s}. b) Is easy to {dis}prove with a o-scope; without it takes some experience & judgement. One clue is it can't generate full current when loaded. a) is usually diagnosed by inspection and cleaning the connections; those being the battery ground, the alternator ground, the engine-to-frame ground, etc... 2) Note that while the alternator IS the source; it may not be at fault at all. The mike line should be grounded at one and ONLY one place... An added, improper ground on a mike jack may make a nasty ground loop. That can be as simple as the insulating washers having slipped. Mike jacks mounted in a metal panel may have insulating shoulder washers: --|-- --|--- washer | | \-- --/ w/shoulder -- -- -- -- metal panel -- -- /-- --\ | | --|-- --|-- The panel hole is bigger than the jack shaft. The shoulders sit in the hole; holding the jack's shell centered away from ground. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
And the Faggot Left continues to whine and Snivel | T Bird | Naval Aviation | 1 | June 13th 05 08:31 PM |
Alternator field cycling & alternator damage | Nathan Young | Owning | 7 | November 14th 04 09:02 PM |
q alternator 152 | Euromotors | Piloting | 2 | July 16th 04 09:34 AM |
Japanese Whine Over Enola Gay Display | [email protected] | Military Aviation | 42 | December 19th 03 11:32 PM |
Electric whine in the light circuit - Help | Victor J. Osborne, Jr. | Owning | 1 | July 29th 03 11:36 PM |
