Mxsmanic wrote:
Tim writes: If you don't believe that if your clearance limit is the airport and that you can pick any approach and IAF and execute it when lost coms, then you can try this: from "Instrument Flying Handbook" FAA H 8083 15 page 10-11 http://www.faa.gov/library/manuals/a...-8083-15-2.pdf "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." That last part might be difficult without a radio. Huh? The OP was confused about what to do at a clearance limit - regardless of radio contact. He asserted that at that point he would have to improvise. That is not the case. Why did you even bother to reply to this? |
In article , Tim
wrote: The OP was confused about what to do at a clearance limit - regardless of radio contact. Not so. My original question was: "what should I have done if I'd been in IMC and lost comm before they changed my routing? This is the fourth or fifth time you've incorrectly put words in my mouth. What is your problem? rg |
Ron Garret wrote:
In article , Tim wrote: The OP was confused about what to do at a clearance limit - regardless of radio contact. Not so. My original question was: "what should I have done if I'd been in IMC and lost comm before they changed my routing? This is the fourth or fifth time you've incorrectly put words in my mouth. What is your problem? rg Are you ****ing kidding me? Did you NOT say this? "And fourth, the regs leave a lot of stuff unspecified. If you go by the regs in the current situation, you end up over KVNY at 11,000 feet, at which point you're supposed to initiate your descent. But there's no published hold at KVNY (to say nothing of the fact that KVNY is not an IAF for any approach to KVNY) so you have no choice but to improvise at that point." I am not putting words in your mouth. It is clearly there for all to see. Your actions in that case are specified regardless of whether you lost comms or not. That is why I had to post to msmaniac. You did not know what to do at a clearance limit if there was no published hold. Or are you going to refute that? |
In article , Tim
wrote: Ron Garret wrote: In article , Tim wrote: The OP was confused about what to do at a clearance limit - regardless ^^^^^^^^^ of radio contact. ^^^^^^^^^^^^^^^^ Not so. My original question was: "what should I have done if I'd been in IMC and lost comm before they changed my routing? ^^^^^^^^^^^^^ This is the fourth or fifth time you've incorrectly put words in my mouth. What is your problem? rg Are you ****ing kidding me? No. Please re-read the exchange and pay particular attention to the highlighted passages. rg |
Ron Garret wrote:
In article , Tim wrote: Ron Garret wrote: In article , Tim wrote: The OP was confused about what to do at a clearance limit - regardless ^^^^^^^^^ of radio contact. ^^^^^^^^^^^^^^^^ Not so. My original question was: "what should I have done if I'd been in IMC and lost comm before they changed my routing? ^^^^^^^^^^^^^ This is the fourth or fifth time you've incorrectly put words in my mouth. What is your problem? rg Are you ****ing kidding me? No. Please re-read the exchange and pay particular attention to the highlighted passages. rg There is no difference on what one should do at a clearance limit and no published hold whether or not you are nordo - you do the same thing. Hold on the course you were flying to the fix. |
Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 04:19 PM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 09:53 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
