![]() "Stuart & Kathryn Fields" wrote in message .. . I welded 4 aluminum gas tanks ( I busted the first two in an incident) and one oil tank for my Baby Belle. I don't remember having much warpage, but I also recall someone telling me to tack the things in a lot of places before finishing the seam welds. The things pressure tested to 14' of water the first time with no pin holes. Now if that doesn't prove luck is better than skill I'll eat a welding rod. I also welded some aluminum beer cans together, but they wouldn't hold mashed potatoes after I finished with them let alone a liquid. -- I have welded a lot of aluminum, including successful welding of beer cans. And I second all of Stewart’s advice. When welding .030 and up, you will want to tack weld even as close as every two to three inches before beginning your finishing welds. Skip welding helps as well, meaning weld between two tacks, skip between two tacks, and weld between the next. It will all help to avoid distortion. Also, clean, clean, clean. Scrape or buff everything with stainless steel rotary brushes, cleaned thoroughly in acetone or eqv. If you pick up any oil or grease anywhere, clean your scrapers and brushes and start all over. It even helps to handle everything with clean cotton gloves. You can leave enough oil from your bare hands to affect the quality of your welds, unless you keep your hands washed in acetone, which I certainly don't recommend. As for thinner than .030 or so, good luck without good fixtures. I have seen some soldering techniques advertised the might be very workable, but have never tried any of them. As for glue, I haven't tried many, but have had pretty good luck with 3M - 2216BA. I don't know how it compares to the others mentioned above, but it has worked well for me. On a seam of .010 with a half inch overlap, I personally think it might be workable, but haven't done it my self. And if you plan to glue, don't for a minute underestimate the value of cleaning, preparation and a good primer. When done correctly under aircraft conditions, actually mixing the epoxy and gluing your seam is only about 10% of the battle. Proper cleaning, priming and curing of the primer is actually more critical. Free advice, your results could easily vary. Max |
aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 08:06 AM |
joining the traffic pattern quandary | [email protected] | Instrument Flight Rules | 77 | January 17th 05 05:07 PM |
Considerations for joining flying club | Marty Ross | Instrument Flight Rules | 20 | September 30th 04 05:55 AM |
Considerations for joining flying club | Marty Ross | General Aviation | 17 | September 16th 04 10:54 AM |
Joining the USAF | jshmoe | Military Aviation | 25 | November 13th 03 05:18 AM |
