Lowrance 2000C ???
Old March 15th 07, 03:09 PM posted to rec.aviation.owning
Mark Hansen
Default Lowrance 2000C ???
On 03/14/07 21:28, Darrel Toepfer wrote:
Mark Hansen wrote:
In reading the documentation for the 2000c, the manufacturer expects
the batteries to be used as an emergency backup only, and that normal
operations of the unit should be via ship power.
FYI
But old planes tend to have crappy ship power outlets, frequently they are
even disconnected...
And the manufacturer says in that case, you can use a supplemental battery
supply which they can sell you. Most people who purchase the unit will have
ship power though, and won't need it.
My point was that it is unreasonable to expect the unit to do something which
the manufacturer says it is not designed to do.
Old March 15th 07, 04:40 PM posted to rec.aviation.owning
Mike Noel
Can the 2000C also operate with the backlight off? I can get 10+ hours on
the internal battery of the GPSMap 296 when using reflected ambient light
instead of the backlight. The reflected light is usually adequate for
daytime use.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Time flies like an arrow, fruit flies like a banana.
"Mark Hansen" wrote in message
FYI
are
have
which
Old March 15th 07, 05:39 PM posted to rec.aviation.owning
Mark Hansen
daytime use.
I read in the user's manual that the backlight can be turned on and off.
I don't know how long the unit would run on the batteries with the backlight
off.
Old March 16th 07, 12:30 AM posted to rec.aviation.owning
Jay Honeck
off.
I find the 2000c to be virtually un-viewable without the backlight
on.
Since I have it permanently plugged into ship's power, that's not a
problem for me. However, if I needed a GPS for use in a plane without
an electrical system, this would be serious drawback.
Jay Honeck
Iowa City, IA
(Presently in Memphis, TN)
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Lowrance 2000c 1.7 update Greg Copeland Owning 6 June 26th 06 08:17 AM
Lowrance AirMap 2000c update Stephen Farris Instrument Flight Rules 0 June 4th 06 02:24 AM
Lowrance 2000c update Stephen Farris Products 0 June 4th 06 02:18 AM
No XM Weather For Lowrance 2000c...yet Jay Honeck Piloting 7 April 14th 06 08:31 PM
Lowrance Airmap 2000c Jeremy Lew Piloting 3 May 18th 04 09:01 PM
