Jim Macklin wrote:
To add or remove from the aircraft, the Airframe license is required or the avionics technician must be working under the supervision of an A rated mechanic or in an FAA Repair Station. Most avionics techs do not hold an FAA certificate as a mechanic, however they are required to hold an FCC certificate in order to make any repairs to transmitters, such as comm radios, transponders and radar. After getting the required FCC certificate and endorsements for the transponder and/or radar they usually will attend factory schools for specific hardware/manufacturers. Ok, that makes sense. Given that I hold a valid FCC General Radiotelephone license, I presume I can do my own panel work providing.. 1. Any structural or weight and balance issue is signed off by an A or A&P rated mechanic. 2. Any required calibration is done by a shop having the proper instruments and factory training. Does that sound reasonable? |
Sounds good to me. Check FCC and FAA rules, part 43 and 65
for FAA, as well as 91. FCC you;will need to look for the special endorsements. Talk to your local A&P/AI and make arrangements for supervision and endorsements of work in progress and finished for return to service. "Jim Stewart" wrote in message .. . | Jim Macklin wrote: | To add or remove from the aircraft, the Airframe license is | required or the avionics technician must be working under | the supervision of an A rated mechanic or in an FAA Repair | Station. | | Most avionics techs do not hold an FAA certificate as a | mechanic, however they are required to hold an FCC | certificate in order to make any repairs to transmitters, | such as comm radios, transponders and radar. | | After getting the required FCC certificate and endorsements | for the transponder and/or radar they usually will attend | factory schools for specific hardware/manufacturers. | | Ok, that makes sense. | | Given that I hold a valid FCC General Radiotelephone | license, I presume I can do my own panel work providing.. | | 1. Any structural or weight and balance issue is | signed off by an A or A&P rated mechanic. | | 2. Any required calibration is done by a shop having | the proper instruments and factory training. | | Does that sound reasonable? |
![]() Given that I hold a valid FCC General Radiotelephone license, I presume I can do my own panel work providing.. 1. Any structural or weight and balance issue is signed off by an A or A&P rated mechanic. 2. Any required calibration is done by a shop having the proper instruments and factory training. Nope, you presume wrong. The work must be done in an FAA approved repair facility. Your general phone only qualifies you to work in such a facility. |
Certificated a/c, inexpensive epoxy primer, autobody? | Michael Horowitz | Home Built | 8 | October 23rd 06 06:36 PM |
McCulloch J-2 certificated gyroplane for sale | Kensandyeggo | Aviation Marketplace | 0 | August 29th 06 06:25 AM |
Ew Avionics | Jean-Paul BERRY | Soaring | 1 | March 8th 05 10:37 AM |
avionics | benmen | Piloting | 1 | January 5th 04 04:17 AM |
F-8 avionics | Zajcevi | Military Aviation | 0 | August 20th 03 11:00 PM |
