A logging question
Old March 17th 07, 02:14 PM posted to rec.aviation.piloting
C J Campbell[_1_]
Default A logging question
On 2007-03-16 00:27:03 -0700, Austin Gosling said:
Hi all. I've been reading this group for a while, but this is my first
post here.
I have a US PPL, and I travel to Montreal frequently on business. I
went over to the Montreal Flying Club at St. Hubert last week to see
about flying in Canada. Evidently, under reciprocal agreements, I can
easily get a Canadian license. Basically all I need are a Canadian
medical and a short written test.
While I was there, I made a short flight up the St. Lawrence with one
of their instructors. I did all the flying, but I have logged it as
dual, but of course the tail number is a "C-....". The question is,
what are the rules regarding the time logged under a foreign license?
Can it be applied for requirements for advanced ratings on the US side?
Or does time in a "C-...." only apply for Canadian ratings?
Also, if I were to get a Canadian license, then a seaplane rating on
it, for example, would the seaplane rating apply for my US license? Can
I get both upgraded at the same time?
By the way, if you are ever in Montreal, I can highly recommend a stop
by the Montreal Flying Club at St. Hubert airport on the south shore.
Very nice folks and very well maintained aircraft. Also a very nice
little airport.
Regards,
Austin
You need to arise about two in the morning and get your gear set up so
that you can begin at first light. Be sure that you knock off by noon
or the forest will be too dry and present a fire hazard.
Oh, you meant a different kind of logging...
If you get the seaplane rating on your Canadian license, you just go to
an American FSDO and apply for a new certificate. The reciprocal
agreements apply both ways. The time you fly in a Candadian aircraft
applies for advanced ratings in the US.
Further questions probably should be directed to the FSDO as to the
actual mechanics of it.
Waddling Eagle
World Famous Flight Instructor
Old March 17th 07, 07:40 PM posted to rec.aviation.piloting
Austin Gosling
post here.
side? Or does time in a "C-...." only apply for Canadian ratings?
Can I get both upgraded at the same time?
little airport.
Regards,
Austin
that you can begin at first light. Be sure that you knock off by noon or
I'm a lumberjack, and I'm OK, I work all night and I sleep all day ...
Oh, not that kind of logging
Thanks for the info.
Old March 18th 07, 04:26 AM posted to rec.aviation.piloting
Jim Macklin
A certificate [license] issued on the basis of a US
certificate in Canada would have the same ratings that are
on the certificate you hold. It cannot be amended. It will
probably be limited to non-commercial operations [if based
on a commercial].
You can get a full license in the USA or Canada, using
experience from one or both countries and that license can
be amended only by a Form 8710, instructor sign off and
flight test. But the hours and such can be counted.
For example, if you have a US CP ASEL and go to Canada, they
can issue a license based on the commercial you hold with
those same rating and it will probably have the
limitation --Private privileges only--.
If you want a seaplane rating, you need to get a complete
issue of a Canadian license or take your flight test from a
USA CFI [who could be in Canada]. Once your base license is
amended, you can get a new --based on-- license with the new
ratings.
Canada can't amend a USA certificate and the USA can't amend
a Canadian certificate.
"Austin Gosling" wrote in
message ...
this is my first
| post here.
business. I
last week to see
agreements, I can
a Canadian
Lawrence with one
logged it as
question is,
foreign license?
on the US
Canadian ratings?
seaplane rating on
US license?
recommend a stop
the south shore.
a very nice
| little airport.
| Regards,
| Austin
gear set up so
you just go to
reciprocal
Candadian aircraft
FSDO as to the
all day ...
PIC logging question Roger Worden Soaring 1 January 8th 07 06:48 AM
IFR logging question - is this legal? Brad General Aviation 46 July 10th 06 10:47 PM
IFR logging question - is this legal? Brad Instrument Flight Rules 51 July 10th 06 10:47 PM
Logging Approach Question Gerald Sylvester Instrument Flight Rules 41 September 23rd 05 12:31 PM
Time logging question... hellothere.adelphia.net Rotorcraft 1 September 3rd 04 12:04 AM
