Canals in Missouri?
Old March 17th 07, 10:51 PM posted to rec.aviation.piloting
BT
Default Canals in Missouri?
If I'm getting flight following... and the ATC controller recommends a
divert around a HOT MOA.. and I refuse...
I can expect his next transmission to be, "Roger, radar service terminated,
squawk 1200, good day and good luck."
BT
thlink.net...
"Jay Honeck" wrote in message
On our flight from Memphis, TN to Iowa City, IA, today, we were
diverted around the Lindbergh MOA.
Congratulations! When did you add the instrument rating?
Old March 17th 07, 11:33 PM posted to rec.aviation.piloting
Steven P. McNicoll
"BT" wrote in message
terminated, squawk 1200, good day and good luck."
Why do you expect that?
Old March 18th 07, 10:52 PM posted to rec.aviation.piloting
BT
I have been on both sides of the mic. If a VFR aircraft chooses to proceed
through a HOT MOA and mix it up with fast fighters doing ACM (air combat
maneuvers) and I am not controlling the fighters.
He is on his own.
BT
news
Old March 18th 07, 11:00 PM posted to rec.aviation.piloting
Steven P. McNicoll
He is on his own.
Weak stick.
Old March 19th 07, 12:33 AM posted to rec.aviation.piloting
Morgans[_2_]
Weak stick.
How so? He was advised to go around, and chose not to. If it was a good
idea to go through, he would not have suggested to go around.
I would not fault a controller not wanting any part of a flight through a
hot MOA. Are you saying that you would be happy to continue being
responsible, as a controller, for a plane flying through a hot MOA?
Jim in NC
Old March 23rd 07, 09:27 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Morgans" wrote in message
Not the pilot, "weak stick" refers to a poor controller. BT said he has
been on both sides of the mic, and would terminate flight following for an
aircraft that chose to go through a hot MOA.
Been there, done that. But ATC is not responsible for separation between
the using aircraft and VFR aircraft that choose to fly through a MOA.
Flight following is simply traffic advisories.
First woman in Missouri Air National Guard awarded Bronze Star Associated Press Otis Willie Military Aviation 0 May 8th 04 09:47 PM
NW Missouri aircraft spotting mah Military Aviation 0 October 12th 03 12:03 AM
Where to soar near JefferonCity-Missouri? Jim Culp Soaring 0 September 15th 03 07:15 PM
Where to soar near Jefferson City - Missouri? Peter Soaring 2 September 15th 03 03:29 PM
