Canals in Missouri?
Old March 17th 07, 11:33 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Canals in Missouri?
"BT" wrote in message
If I'm getting flight following... and the ATC controller recommends a
divert around a HOT MOA.. and I refuse...
I can expect his next transmission to be, "Roger, radar service
terminated, squawk 1200, good day and good luck."
Why do you expect that?
Old March 18th 07, 10:52 PM posted to rec.aviation.piloting
BT
I have been on both sides of the mic. If a VFR aircraft chooses to proceed
through a HOT MOA and mix it up with fast fighters doing ACM (air combat
maneuvers) and I am not controlling the fighters.
He is on his own.
BT
news
Old March 18th 07, 11:00 PM posted to rec.aviation.piloting
Steven P. McNicoll
He is on his own.
Weak stick.
Old March 19th 07, 12:33 AM posted to rec.aviation.piloting
Morgans[_2_]
Weak stick.
How so? He was advised to go around, and chose not to. If it was a good
idea to go through, he would not have suggested to go around.
I would not fault a controller not wanting any part of a flight through a
hot MOA. Are you saying that you would be happy to continue being
responsible, as a controller, for a plane flying through a hot MOA?
Jim in NC
Old March 23rd 07, 09:27 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Morgans" wrote in message
Not the pilot, "weak stick" refers to a poor controller. BT said he has
been on both sides of the mic, and would terminate flight following for an
aircraft that chose to go through a hot MOA.
Been there, done that. But ATC is not responsible for separation between
the using aircraft and VFR aircraft that choose to fly through a MOA.
Flight following is simply traffic advisories.
First woman in Missouri Air National Guard awarded Bronze Star Associated Press Otis Willie Military Aviation 0 May 8th 04 09:47 PM
NW Missouri aircraft spotting mah Military Aviation 0 October 12th 03 12:03 AM
Where to soar near JefferonCity-Missouri? Jim Culp Soaring 0 September 15th 03 07:15 PM
Where to soar near Jefferson City - Missouri? Peter Soaring 2 September 15th 03 03:29 PM
