On Mar 20, 11:53 am, "kevmor" wrote:
How can you adjust an altimeter if the pressure isn't correct in the window for the altitude? I started talking to my examiner about it on the checkride and he said that a lot of people adjust it themselves (not an avionics shop, etc), and he said you take the front off (I think) and theres a screw to adjust it? The plane would be used for VFR only... Is there an adjustment that can be made to the encoder as well if it's off? http://www.cozybuilders.org/newsletters/news_30.html It's easy enough to do if you want to. BUT It's a) not legal and b) adjusting the altimeter at your airport elevation may make it totally out of spec at cruising altitude. The instrument shop adjusts it so that it's in spec over the entire range of altitudes, not just correct at one particular one. Ed |
Altimeter 3066 | M | Piloting | 24 | December 4th 06 06:46 PM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Altimeter Disassembly | Dick | Home Built | 3 | April 2nd 05 01:27 PM |
encoding altimeter | mcfrog | Owning | 3 | May 30th 04 07:39 PM |
low altimeter and FL180 | Michael 182 | Piloting | 26 | October 31st 03 04:29 AM |
